Pre 84 Trucks 1st gen pickups
Leaf spring eye bolts?
Old Dec 3, 2013 | 02:14 PM
-Yoda-'s Avatar
Anybody know where I can find the spring eyebolts for the front and rear spring mounts? I fubared mine trying to get them out.
I'm looking for the ones that have the bracket at the end with the two 10mm bolt holes on each side.
Old Dec 3, 2013 | 03:08 PM
gillesdetrail's Avatar
rockauto.com has them and I was told autozone has it if you are in the US.
Old Dec 3, 2013 | 09:37 PM
kawazx636's Avatar
I bought some from AutoZone (DuraLast) that worked perfectly. I powdercoated them before I installed them too since that were raw steel. I have the receipt at work, if you want a part number I can check for your tomorrow.
Old Dec 4, 2013 | 12:59 PM
catfish21's Avatar
Hey kawaz I would like the part number
Old Dec 4, 2013 | 01:17 PM
81yotacarlos's Avatar
First time posting long time reader of this forum. Ok, I too would like to use stock bolts and have done lots of searching. I considered using these http://coolfj40.stores.yahoo.net/pinkitsprinh1.html
But I wasn't sure if they would fit. Some do say they are oem but want to confirm that before I order. I emailed them and they weren't very knowledgable about their products.
Old Dec 4, 2013 | 03:32 PM
Personally I used trail gear greasable bolts, but I had to make the hole on the hanger bigger. My comment might not help you in a direct way but at least you know there is another option if you don't want to pay 15$ for a bolt!
Old Dec 4, 2013 | 09:07 PM
kawazx636's Avatar
Auto Zone part number SK8215.
Here's the link for them:
http://www.autozone.com/autozone/par...artNumber=true
Looks like they don't have them in stock, but you could always call and check.
The link that 81YotaCarlos posted will not work without modifications. Those pins are for FJ trucks. There is a shoulder on the pin that should fit snugly in the hanger, but on the FJ pins that shoulder is larger in diameter.
Old Dec 4, 2013 | 09:49 PM
Thank you Kawazx636 for the information. I was hoping they would work so I had some greasable pins but now I will either use trail-gear pins or just order some OEM pins from autozone.
88sasturbotoy
Jan 30, 2026 01:57 PM
nvdesertrunner
May 11, 2020 08:18 PM
4x4-runner
Apr 18, 2017 09:08 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
Greene916
Aug 10, 2015 01:45 PM
