Broken locker or axle shaft?
Hello, so today in a parking lot i backed out of a spot, put it in first and when I took off I heard a loud "pop" like something breaking. I drove home, it drove fine besides tire breaking loose in drive way. Anyway I noticed on ice in my drive way I can only get the passenger tire to spin.
I was told it has a Detroit locker. (I've seen both tires spin off road I know it locked) and I'm 90% sure it wasn't welded I can turn in parking lots sharply with out chirping tires.
So when I got home I jacked up the rear with both tires off the ground. And with it in neutral, if I spin the drive line only the passenger tire spins. And I can manually spin the drivers side. Not very easy but it's not really hard either.
Anyway what I was wondering is could it be I broke the axle shaft on the drivers side? Or could there be something in the diff? Detroit locker broke? I really need help I'm not looking to put too much more money in this year.. Thanks
It's pretty easy to pull the axle. Take off the tire, take the brake line out of the brake cylinder for that tire. Remove the (4?) bolts, and slide the axle out. Shouldn't take much more than a half hour to have the axle shaft out.
See how it looks...
See how it looks...
The sound you heard could have been the locker unloading. I have a lockrite and it will make a loud bang every now and then, sounds like a u-joint exploding. The sound usually occurs right after changing directions, with light to no throttle.
I don't know what it is. I just figure that rather than sitting around thinking about it, it might make more sense to have a look and find out for sure.
If one of the two are broken, the axle shafts are going to have to come out either way...
Put it on jackstands and lock it in gear and turn the tires by hand, if the drivers spins freely, then start pulling things off. If you pull the drivers axle shaft out and there is no sign of breakage, then its the locker
Both the axles and the locker are pretty easy to take out.
Once you learn how to get one axle out...the other axle is the same exact process. From there, getting the rear diff out is just a matter of unbolting the rear driveshaft from it, and taking out the bolts around the housing. Then it pulls right out.
After draining the fluid...
You don't really fix a broken rear diff...just replace it. Unless you know someone who will work on it for cheap.
So I took the drivers shaft out and it's broken right at the end
It's seems that right inside the housing right where it broke it a little chewed up. Will I need to replace the whole axle? It wasn't leaking. And any info on where to buy a shaft? Napa said 350 plus shipping from across the country. Not looking to spend that much. Thanks
