Pre 84 Trucks 1st gen pickups
1983 toyota 22r overheating
Old Nov 4, 2013 | 11:07 AM
fatiguy's Avatar
Unhappy 1983 toyota 22r overheating
I was riding home yesterday when all of a sudden I notice I lost all heat inside the cab. I kept going for a bit and noticed my temp gauge going up. So I stopped and took a look at a few thing. Noticed coolant was down... when I got home, topped up the coolant and let it run for about 15min. I have heat again but the coolant is foaming up. There is no sight of a coolant leak, or coolant in the oil. Can you please help? What is causing the coolant to foam?
Old Nov 7, 2013 | 09:35 PM
jhearold's Avatar
Maybe a compression leak?? R u getting coolant in the over flow?
Old Nov 8, 2013 | 06:09 AM
83's Avatar
83
Well the coolant is going somewhere...
If there's no leak you can see, you're either burning it or it's going in the oil.
Sounds like you're losing compression, and it's going into the coolant. You can have your coolant tested for exhaust gas. Or do a compression test/leakdown test.
Could be head gasket...
Old Nov 8, 2013 | 11:04 PM
fatiguy's Avatar
Overflow was full, radiator was pretty much empty...
Old Nov 12, 2013 | 06:21 AM
jhearold's Avatar
Probably a head gasket... I would do what he said and maybe do a compression test.
Old Nov 12, 2013 | 06:49 AM
HighLux's Avatar
fill the radiator with water. leave cap off....rev it up . water shooting out radiator? If so welcome to team headgasket.
Old Nov 12, 2013 | 08:55 AM
snobdds's Avatar
Every diagnosis of an overheating situation should begun with a coolant pressure test. No need to get water in your face if you don't have too...
Old Nov 12, 2013 | 08:57 AM
HighLux's Avatar
It would do some people some good...lol.
Old Nov 17, 2013 | 06:42 PM
jhearold's Avatar
Lol X2
Colington
Mar 8, 2020 09:51 AM
nick b
Jul 11, 2015 04:38 AM
87blyota
Jul 10, 2015 04:31 AM
Avenged
Jul 9, 2015 07:55 AM
