Pre 84 Trucks 1st gen pickups
4 speed to 5 swap
Old Dec 2, 2013 | 07:38 PM
Bajawfo's Avatar
4 speed to 5 swap
What year can I go up to that will fit an 81? Not much to chose from at the junkyard.
Old Dec 3, 2013 | 05:04 AM
dropzone's Avatar
Fossilized
there is a ton of threads on this...
if you don't mind moving your crossmember back and redoing your front and rear driveshafts just about any G series, W-Series or the wholy grail of 4 cylinders transmissions the R-151 will work.(these transmissions are ~25" long)
if you want to do a direct bolt in replacement you need an L-50 or L-52 (about 21" long)
Old Dec 3, 2013 | 06:16 AM
83's Avatar
83
L50 and L52 are 82 and 83. 84 85 are the G series, then it goes to W (right?). But yes, G and W are slightly longer than your tranny. The L series should all bolt right up.
Old Jun 21, 2014 | 05:46 PM
Bajawfo's Avatar
I'm just going to add that I got a 5 speed installed. It was out of a Celica and the rear mount did not line up, about 2 inches longer. And the shifter was about 3 inches back so I had to cut the floor. Over all it was worth it. The new 5 speed whines like a sports car and I guess it weighs about 100 lbs less as old 4 speed had a cast iron bell housing !
Alex Bessinger
Aug 31, 2015 09:17 AM
deepmarsh
Aug 6, 2015 03:44 AM
kyletbert
Jul 17, 2015 11:39 AM
wilbertd
Jul 6, 2015 07:39 AM
HRDC0R19
Jul 5, 2015 06:43 PM
