Pre 84 Trucks 1st gen pickups
Clutch affecting idle
Old Nov 8, 2013 | 05:40 PM
RandyAk's Avatar
When I let the clutch out at idle it seems to drag on the engine. What causes this and how do I fix it?
Thanks,
Randy
Old Nov 8, 2013 | 07:21 PM
ksti's Avatar
Thanks,
Randy
I'm trying to decode your post, so the word "drag" leads to think your clutch is slipping, maybe a video?
Old Nov 8, 2013 | 07:50 PM
RandyAk's Avatar
No, I mean it feels like the clutch is partially engaging; transmission in neutral, start engine, let out clutch and it is grabbing. What would cause this?
Old Nov 8, 2013 | 09:07 PM
kawazx636's Avatar
The clutch IS engaged with the flywheel if you have the pedal out and in neutral - It just isn't in a gear to turn.
Old Nov 8, 2013 | 09:20 PM
SoCal4Running's Avatar
There is "drag" when the transmission is in neutral. The input shaft is still spinning as well as a few bearings. When you let "out" the clutch in Neutral you will see a minor drop in rpm and then a recovery as the parts spin up.
Old Nov 8, 2013 | 11:07 PM
wyoming9's Avatar
Red face
As the temperature drops the gear oil in the transmission gets thicker so the colder it is the more you notice it.
Being it is likely a 4x4 you also have the gear oil in the transfer case
It might be the wrong gear oil for the temperature.
I had one case where the gear oil was never changed and enough moisture from condensation that it froze now that was a fun one to figure out.
smthwsn357
May 1, 2024 07:28 AM
Blamalam
Mar 12, 2022 07:34 AM
upongame619
Aug 1, 2015 12:12 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
1996Taco
Jul 20, 2015 12:02 AM
