Pre 84 Trucks 1st gen pickups
v6 pinion leaks
Old Oct 11, 2013 | 01:38 PM
kdo58's Avatar
v6 pinion leaks
i put in some used v6 3rds the front one started leaking at the yoke right away. so i got a new seal and took it apart. i was looking at the yoke and it has a small groove in it, i am guessing it will leak again, are new yokes available or some other fix?
Old Oct 11, 2013 | 02:58 PM
rokblok's Avatar
New yokes are available from gear distributors like Just Differentials, East Coast Gear Supply, etc. But you can also get very thin sleeves to fit over the yoke, but that's dependent on application, and I haven't had good luck with them. Some folks have though.
Or you could slightly change the depth of the seal to ride on a different part of the yoke. I've done this before with no problems.
But if the groove is very slight, your new seal may seal it. The old seals get dry and aren't flexible and it starts to leak, whereas a new seal is pliable and can conform better, even if there is a groove.
Old Oct 11, 2013 | 09:16 PM
kawazx636's Avatar
maybe try driveshaftparts.com
Old Oct 11, 2013 | 09:42 PM
aztoyman's Avatar
You can get multi pattern flanges from TG or Marlin or their distributors.
Or do like rokblok said.
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
trailgoat
Aug 13, 2015 05:54 PM
kirkrunner
Jul 27, 2015 07:59 PM
