Pre 84 Trucks 1st gen pickups
Weber Carb Choke issue...
Old Nov 21, 2013 | 04:54 PM
funcrazy1's Avatar
So I just got done rebuilding my 20r and weber also.. I rebuilt the weber first got everything working manual choke pull worked then I pulled the motor to rebuild it now I can't get the choke to engage with the wire.. I was wondering if you can go from manual choke to electric choke? If this doesn't make sense I can make video to get more help.
Old Nov 21, 2013 | 08:28 PM
kawazx636's Avatar
So you're trying to convert a manual choke to an electric choke or is the manual choke not working?
Old Nov 22, 2013 | 06:53 AM
funcrazy1's Avatar
Well the manual choke won't work I can't get the wire to engage the choke I was wondering if you go for manual to electric choke
Old Nov 22, 2013 | 08:07 AM
kawazx636's Avatar
You'd have to get and install the whole electric choke mechanism. Do you push in the gas pedal while you pull out the choke? I'm not 100% sure if you have to do that on all Webers, but I know I do on mine. If I don't push the gas while engaging the choke, it won't fully open.
Old Nov 25, 2013 | 09:27 PM
funcrazy1's Avatar
before i pulled the motor out yes i would have to hold the gas then pull choke.. Now it seems like the wire won't pull the choke I will make a video tomorrow if I don't get off late.
Old Nov 26, 2013 | 09:33 AM
kawazx636's Avatar
Is the choke cable installed properly? If you have the cheap one that comes with the Weber, sometimes it can get kinked and hard to pull. You can also clamp the cable housing down too tie on the carb and cause the wire inside to get pinched so it won't pull properly.
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
the_supernerd
Oct 1, 2015 09:20 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Toys4parts
Sep 26, 2015 01:56 PM
taraf
Sep 25, 2015 02:57 PM
