View Full Version : Pre 84 Trucks
- Questions about this vacuum switch
- fuel pump torque spec, 1986 22r
- 1983 Bucket Seat Covers
- 80 Aisan Carb hose's
- 80 4x4 pickup sputtering when decelerating
- Rhino Lining a whole truck
- 1980 Longbed "Stumble-Bee" Build
- Really?
- Ball joint spacers for 1981 PU?
- Gas tank under vacuum ?
- Hard starting old Toyota? A possible fix....
- Won’t crank/start checklist?
- Pin connectors
- 1980 Seat Swap
- Climate Control nipples - 79 4x4 longbed
- 1980 Hilux Project: 2TR FE Motor Swap
- Brake Booster Leak? Just Replaced MC.
- 81 pickup vacuum confusion, Help!
- 16" Wheels
- Can't Find Fuel Tank Anywhere!!!
- Motor mount heat insulator
- '82 22r spark, fuel, crank, no start, except for the first
- 1980 pickup with a stock 22r?
- 1983 toyota bumper
- Bleeding PITA
- 1978 Toyota Pickup Bent Axle Shaft Help!
- Help! 1981 22r sr5 battery/sensor light on
- Anyone have a solid rear glass they can part with and ship?
- Hey all the 77 experts! R20 chinook wont crank after hot
- Pick up coil doesn't fit?
- no shackles up front?
- Solid Front Axle Ball Joints
- 22R with FJ60 Power Steering Pump
- 1978 Toyota pickup backfires on warmup when letting off gas between gear shifting
- RC Trucks. Picked these up yesterday
- PLEASE HELP! FAILED SMOG 5 TIMES - HIGH NOX - Done Everything I Think Of
- Source for 83 22r BVSV?
- 79 4x4 Tire Size
- Picked up an Old Acquaintance..........
- 83 auto acceleration woes 🤔
- 10 digit Vin Decoder Link
- Locking The Rear Sliding Window
- Custom reproduction seat fabric for sale!
- Tail Light/Brake Light Issue
- 81 manual transmission replacement
- 78 e brake never worked ..?
- Missing hole on replacement carb?
- intermediate plate below stock carb remove?
- leave air injection pump with new weber?
- L43 Trans Drain Plug Ball & Spring?
- hard to get parts?
- What would YotaTech do.
- brake and battery light after replacing Carb?
- 1980 Toyota Celica GT HEI swap
- Seeking 79 PU Heater Control Valve
- Wheel Cylinder Clearance
- 1980 Pickup 20r throttle sticking at full
- Where to find parts
- 83 Automatic 22r dies when Hot
- Ifs box for high steer
- Front differential vent leak
- turbo donor for 1980
- 22r Won't turn off
- 80 22r/20r pickup ignition coil?
- Slow Cranking
- 1979 clutch part
- Rear Tires wont move
- clutch pedal compatible
- 1982 toyota pickup bumper corner extension
- Exhaust header
- Is this hole supposed to be covered? 1983 4x4
- Need a source for those rubber fender shields???
- Photoshop request
- Hard shifting
- 1976 Toyota Chinook Won't Start!?
- Mystery vacuum hose from the transmission
- Gas Pedal
- 79 4x4 Wont Start
- Parking Brake and Fuel Skid Plate
- 82 Pickup Build Crossroads
- L43 Shift shaft bushing/oil seal removal?
- '83 Mojave, what's it worth?
- Need a 2 1/4" cat-back exhaust system for an '83
- VSV (Valve Switching Valves)
- ‘82 4x4, GM LV3 4.3l Engine Swap
- 22r timing problems
- Truck to trailer conversion Project
- L43 Shifter Shaft Housing Q:
- 1979 Truck SR5 Accelerator pedal
- 1981 pickup motor swap. Advice?
- 22R chirping under load
- Nerf bars install
- '83 SR5 4x4 sells for $50K!
- slight heating issue on my 83
- Rough idle after exhaust fix
- 1981 CA 4x4 4x2 compatible parts questions
- Transfer case mount replacement
- 1981 Exhaust Replacement - What are my options
- 22r stumbles and loses power accelerating or going uphill
- Which Replacement Alternator 1983 4X4
- EGR valve modulator
- Transfer case vibration
- My daily 1980
- Source for bed repair panels?
- 1980 Non Tach gauge cluster change over
- Bench seat for my 80
- Fisrt gear pops out
- 1980 4 speed shifter positions
- Changing Rear Window
- 20R Engine Service Manual ONLINE or Download FREE
- Cold idle issue. Advice needed.
- 83 22R alternator removal route out of engine bay
- 22R dies when throttle applied
- 82 build
- 21r carburetor
- '82 22R blowing up coolant system components and over heating
- What are these pieces found in my oil pan?
- Ignition Coil Specs for 20R, 22R, 22RE HERE-1975 to 1988
- Fuel pumps keep leaking 22r
- Will a 22r distributor vacuum advance fit on a stock 20r distributor
- TACH/SPEEDO cluster compatability/conversion
- 1980 Toyota Pickup - Help finding wheels
- No AC after desmog
- 80 side shift clutch not disengaging. 2wd 20r
- AC retrofit confusion
- Ignition cylinder troubleshooting
- Valve stem seals
- Trouble in bed.
- Changed out the Clutch Master Cylinder
- SR5 Cluster Swap in an 80
- Who has pics of their Skids for 79-83 4WD?
- Starter ID - 1981 Pickup 4x4
- Wiring an Aftermarket Tachometer
- Daul Row Timing Chain Installed But Very Slack
- 1980 base 4x4
- '82 22r mystery part with missing vac line
- Couple of videos of driving Dixie today.
- New Fan Clutch
- Looking for the best carb and intake setup for my 22r.
- Gear Shift arm Pads/Wheel well liners
- Bucket Seat Rebuild?
- 82 4WD Electrical Issues
- Found a good looking mirror
- 1982 doors sweepers
- 1979 2WD W42 -- Shifter Seat?
- 2nd gen AC into 1st gen?
- while doing a carb. to efi conversion on a 85 toyota 22r
- 81 4x4 electrical problems
- Results: Weber High Altitude Re-jetting
- 1981 4x4 pick-up dilemma
- Says Weber...
- Parking brake bell crank???
- 22r runs bad climbing
- 1980 4x4 pickup Wheel cylender
- Hacked up wiring harness
- L52 transmission with l43 t ase 1980 yoda
- Fuel and Temperature Gauges
- 81 2 W SR5 Aisian Carb idle/ fast idle issues
- 1981 22R California 4x4 Smog Vacuum Diagram Question
- Front Axle Removal
- Ring gaps on a 20R
- Replacing Smog Pump on 20r w/ GM 1 Wire Alternator?
- Brake shoes
- What years were the Toyota Pickups made and sold in the US.
- Must be nice haha
- My 81 2 Wheel drive is one inch higher on the driver side?? I have 3 inch lower block
- Transmission ID & Help
- Soooooooo I And I’m the proud owner of a 1983 Trekker that is in need of restoration.
- Towing a first gen 4x4 via dolly?
- transmission swap
- 1975 20R Missing Oil Galley in Timing Chain Cover?!?!
- 1980 pickup 4x4 bumper
- '75 20R High Oil Pressure Blowing Oil Filter Gasket
- T-Case Leak
- 1981 Hilux with 1993 pickup a/c unit?
- Surging idle and misfires, 77 20r
- Noticed a couple drops of coolant. Pics
- 22R and White smoke.
- Our '83 is finally "Weberized"!!
- comments my little restoration of my truck 1982
- Not even comparable.
- 22r no idle advance
- 83 torsion bar options.
- Aluminum radiator help, 82 yota 4x4 manual trans
- 22r no idle
- Air intake boot
- 82 sr5 climate control?
- New Weber, Won't Start
- Distributor Installation
- Is this about avg for a 1st gen? 40-60mph video
- Emissions Switch
- Selling a 1982 4x4 with a rusting bed...rough idea on street price?
- What is this tool in the tool kit
- HAC Check Valve
- Possible cause of off center steering wheel?
- Fitting Leaf Springs
- Removing Steering Box
- I need a factory bolt, picture in thread message
- VERY black old engine oil???
- 1988 toyota pickup 22r
- 1978 20r Issues
- Take a look at my leaf springs.
- What will it take to fix This! Floor pan/cab mounts
- Acceptable driveshaft play? See video
- rétro-fit sun visor
- Under Hood and Bed LED's
- First gen tach not working
- Exhaust manifold help!
- Opinions on Weber conversion for a 1983 22R
- 83 Single cab conversion to a quad?
- Signal Light Issue
- Front main seal leak?
- 20R offy intake PCV inlet location?
- 20r Exhaust Manifold Gasket Question
- Tilt Steering Problem
- Smogging a de-smogged '83
- 20r Valve Adjustment
- Leaf Springs Stock Height
- Clutch...
- Is my starter going out? Recommendations please
- Rebuilding 81 pickup with an 85 22r ?s
- Pulling Heater Core
- Low Compression In Cylinder #1
- Bench seat swap
- How to fix body seam?
- Body leans to drivers side on 1983 4x4
- Shifter boot removal?
- *New Truck* 1982 Toyota Pickup 4wd, stored 20 years.
- replacement bucket seats for a 1981
- early '83 22r, broken timing chain ... and valves?
- Weird Situation, Need Advice
- Power steering pump
- new cylinder head on 4g64 sohc 16v mitsubishi
- Jam Nuts
- Window Handle Alternative
- Sliding window latch?
- What's this part called?
- 5 Pin Regulator Test?
- Help!, 1980 20r coolant and vacuum line mystery
- '83 charging issue
- Window Cranks - on new door panel
- Iratic idle on a 79 pickup engine
- Painting a plastic center tray
- no power to coil
- Dome light LED
- 6 x 170 mm bolt pattern
- 1980 4x4 20r to 22r Engine Swap
- Detroit locker?
