Pre 84 Trucks 1st gen pickups
79 4x4 Wont Start
Old Oct 20, 2018 | 07:29 AM
albertb's Avatar
79 4x4 Wont Start
Hello everyone. I am new to Toyotas. I just bought a 79 4x4 with a 20r with 150k miles.
The good-
New headers
Weber Carb
No frame rust
All original Parts
The Bad
Won't start because of no compression due to a "cylinder seal" (according to the guy I bought it from)
I can see the truck getting fuel and it cranks perfectly. My question is what is my best option to get it running good. I have a decent budget and I was wondering if I should get a new engine, rebuild this one, or do something else. The issue is I live in Montana so parts are a little harder to come by and I pretty much have to order everything if NAPA doesn't have it.
Thanks
Old Oct 20, 2018 | 08:56 AM
Corey Barlow's Avatar
Do you have spark? Do a compression test if you have spark
Old Oct 20, 2018 | 09:21 AM
Lons81's Avatar
That is good start. Don't know what the mechanic's term was for " cylinder seal", other than possibly bad piston rings not creating the compression needed for ignition
Old Oct 21, 2018 | 09:54 AM
albertb's Avatar
I talked to NAPA and a "new" 20r would be $1,500 and a 22re would be $1,800. Couldn't find any motors on craigslist. Should I rebuild or just drop a new motor?
Old Oct 21, 2018 | 11:16 AM
dropzone's Avatar
Fossilized
22RE won't work in your truck, unless you convert your truck to an RE.
off the top of my head your 20R manifolds etc won't match up plus you would need to convert wiring, need an ECU etc
sounds like your best bet would be find someone to rebuild it
RampartRanger
Apr 10, 2017 03:00 PM
yotarob2005
Apr 5, 2011 11:04 AM
854runner4x4
Jan 26, 2010 09:31 PM
89whitetoyota
Dec 4, 2008 03:31 PM
gtpunk18
Jan 24, 2007 09:25 PM
