Pre 84 Trucks 1st gen pickups
20r Valve Adjustment
Old Jan 14, 2018 | 07:04 PM
Sizzle Chest's Avatar
This might be a dumb question but I can't find any answers searching. When adjusting the valves on the 20r, do I use 8 degrees or 0 degrees for top dead center? You're supposed to use 8 degrees for timing, but maybe that's just for timing? Any info appreciated!
Old Jan 14, 2018 | 07:34 PM
Co_94_PU's Avatar
Consult the manual, or your cam specs? Zero generally, the rockers should be centered in the round section, IE fully closed valves.
Old Jan 15, 2018 | 08:32 AM
millball's Avatar
TDC for valve timing. 8 degrees is for spark timing.
Old Jan 16, 2018 | 08:38 AM
Thanks. The more I thought about it I realized that had to be the correct answer since spark timing is before top dead center, and you wouldn't adjust valves before TDC. Anyway, thanks again guys!
brian2sun
13
Nov 14, 2011 09:05 AM
broncbob
Nov 24, 2009 12:26 PM
-=j0nnyr0773n=-
Aug 30, 2009 07:40 PM
jason191918
Sep 12, 2008 07:03 AM
CILO
Feb 17, 2006 08:05 AM
