L43 Shifter Shaft Housing Q:
Hi,
Unable to get this "elbow" housing off the shaft in the pic after removing nut w/ wire from "elbow" housing removing shifter arm from above - does this just require some additional pressure to knock it loose? Or, is there something other than the shifter arm & bushing that needs to come out of the vertical part of the housing? Thanks for any insights -
Toyotero
08-13-2008 09:53 AM
