Pre 84 Trucks 1st gen pickups
slight heating issue on my 83
Old Sep 23, 2018 | 03:59 PM
joesgarage's Avatar
So changed out thermostat, fan clutch and radiator. I drive on the freeway for 20min and the gauge starts to go up half way. Once I get off freeway truck starts to cool down. Do I need a bigger radiator, just recently starting to have this problem. driving around town is fine, Not loosing coolent and no leaks any where.
Old Sep 23, 2018 | 04:28 PM
millball's Avatar
Check that your ignition timing is correct and that the timing advances with speed and load appropriately..
Old Sep 23, 2018 | 07:35 PM
L5wolvesf's Avatar
Did you burp the system?
Old Sep 23, 2018 | 08:35 PM
joesgarage's Avatar
Burp
going to try burping thanks.
Old Sep 24, 2018 | 08:19 AM
Punjab's Avatar
Yeah, air bubble or bad thermostat would be my first guesses.
Old Sep 24, 2018 | 02:06 PM
joesgarage's Avatar
Heating
thermostat has been changed.
Old Sep 28, 2018 | 04:12 AM
rickc5's Avatar
Yes, but is the new one working correctly. It can be tested by pulling it out (yeah, I know it's a pain) and placing it in a pan of water on the stove. Using a cooking thermometer, slowly heat the water and see what temp the thermostat opens.
Old Oct 18, 2021 | 04:15 PM
joesgarage's Avatar
Still over heating
I don’t see the radiator fluid circulating. So thinking of changing the water pump out.
95yota22repickup
May 19, 2010 03:07 PM
dwest76
Dec 15, 2009 02:16 AM
weaselman
May 25, 2009 07:45 PM
yotasavg
Aug 10, 2007 09:30 AM
Lone4runner
Aug 2, 2006 06:10 PM
