PDA
View Full Version : Pre 84 Trucks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25
  1. Custom Door Panels...?
  2. 20R Loss of power then power.
  3. Manual/Automatic Question
  4. 81 pickup dash lights
  5. Voltage regulator question
  6. Softtopper Canopy fit?
  7. New guy, performance and parts
  8. Need some advice on rocker arm removal
  9. AC Question
  10. ignitor for 78 hilux (no spark)?
  11. Mounting speakers in 79 Truck.
  12. charging problems please help
  13. Setting Ignition Timing
  14. 80' yota Truck: No tail lights, where to start...
  15. speakers for an 81?
  16. Slave Cylinder question
  17. interior colors on 1st gen trucks?
  18. Clutch quit working
  19. availability on 1979-83 floor pans
  20. Pic/info request for RHD conversion
  21. No Fuel Filter on my 1981 4x4 22r.
  22. Looking for advice on a camper shell/ top
  23. Having problems setting wheel bearing preload
  24. 1982 toyota 4x4 park brake adjustment
  25. front left wheel smoking
  26. Missing VECI label '80 20R
  27. Transfer Case rebuild advice please
  28. 82 Choke Rod Missing?
  29. Post your gauges
  30. SCR's 80' Yota
  31. Lifting Front with stock 48's
  32. Wiper control relay for 80 pickup
  33. Idle Problem
  34. 84 camshaft in 82 pickup?
  35. mystery dash swich
  36. i took my windshield out, dont know what to do now
  37. crankshaft pulley off an '80 20R will work on my '82 22R?
  38. CB Noise Reduction
  39. '82 hit bump, instant bogging????
  40. Picking Up This Truck Saturday
  41. 1980 20R Manual Linkage Replacement HELP!
  42. 1st front axle rebuild, need advice on damaged knuckle!!
  43. rolled my 82
  44. my first toyota truck
  45. installed my weber right... right??
  46. Body Panels
  47. Easter egg hunt: where is the headlight fusible link on an 80 pick up
  48. 81 22r No spark
  49. I have 3 broken rocker arms need advice
  50. 22r with weber 38 dges- backfire issue
  51. What the Heck? Won't start after checking plugs.
  52. 22R Maintenance Time leaking intake gasket and more
  53. Rough idle... Due to charging?
  54. Which vacuum line for Seafoam?
  55. Water mixed with oil and water ontop of Piston
  56. Got my first Toyota Pickup! 1983 4x4!
  57. W-56 trans Qs
  58. 83 Toyota cadet
  59. Sloppy Shifter Fix
  60. 1st Gen with 32" tires?
  61. traded a 12 pack of stag for a 1980 4x4 pickup
  62. Is anyone using a different cam?
  63. truck dies after push clutch in
  64. What shocks are on your 1st Gen?
  65. Terrible Steering
  66. Pulling front axle, have a few questions
  67. Manual Locking Hub Question
  68. 20r to 22re
  69. AC hose for 81 r22 NEEDED
  70. Truck dies while driving, doesn't seem to be igniter coil..
  71. Firewall Gromets
  72. Oil spewing from the block
  73. key wont work???
  74. choke
  75. 88 pickup 5 speed in 82 pickup?
  76. What's the problem? Help!
  77. 81 Toyota carb help
  78. 1980 4x4 with 1981 2wd 22r
  79. 82 longbed gastank in an 82 shortbox! Yes it can be done! Pics
  80. Saw this at a car show today! Toyota Stout 1900
  81. Anyone ever deleted this hose and lived to tell the story?
  82. 1983 Plow Truck
  83. need hood for 82 PU. 86 hood work?
  84. Meet "Junior" - my 83 2WD build
  85. no start no spark
  86. weber carb info
  87. Can-Back
  88. Hub Removal Question - 81 4x4
  89. 81 22r won't idle
  90. What grease fitting for front u-joint?
  91. 22r dies in the morning
  92. Where do you order stock parts? 82 p/u
  93. My 81 yota
  94. Tranny issues
  95. needing emissions/vacuum line help
  96. Thorley Header mounting bolts holes
  97. How do you like your rear Suspension??
  98. Front and rear suspension lift from Wabfab?
  99. how to tear into the L52 transmission
  100. New Weber install - will not idle
  101. help with fuel issue
  102. plastic speedo gear or speed sensor
  103. Seafoamed project banana...
  104. 22R Carb rebuild
  105. Death wobble
  106. entire frame or partial frame replacement
  107. Please Help! I need vacuum!
  108. Long Bed/ Short Bed
  109. What header is the best for a 82 Toyota
  110. Pressure Washing Engine bay?
  111. Charging system only at 12.4 v... Help
  112. Purchased an 83, now wonder...
  113. Side Markers
  114. 1979 toyota help with bvsv please?
  115. 1980 Toyota Pickup Heat stove...
  116. Gone away
  117. 83 fuel tank replacement
  118. ifs box moved forward and high steer still rubbing
  119. 1982 toyota 4x4
  120. Stock carb issue
  121. Replacing my gear box with power steering
  122. Engine decisions: Would like some input.
  123. Need grill!
  124. 81 Toyota leaning/ passenger front higher
  125. new to me 22r smokes and wont idle when hot
  126. Rear Leaf spring question
  127. 93 22re in a 83
  128. YOTATECH gurus unite!!! Strange 82 22r power/ fuel consumption issue???
  129. Rear axle O-ring
  130. 82' 22R Running kinda rough after new head and timing chain
  131. 'Ol Blue Build Thread
  132. Wow.. look at this '80
  133. need pics please
  134. 81 22r in a 80 truck. thermo switches?
  135. 1981 Toyota pickup 4wd SR5 fuel pump ?
  136. temperature gauge all the sudden not working after a rebuilt motor
  137. Got a box full of carbs... which to use?
  138. 83 a/c
  139. 20r sputtering and stalling
  140. parts/project 81 toyota
  141. Snorkel help!
  142. CA Smog for 1st gen 22r Swap
  143. Gave my '80 a facelift
  144. 81 toyota bed
  145. Turn Signal Flasher Location
  146. weber carb smog help...running rich
  147. Help! head gasket job done, timing is another story..
  148. MUST find head for '82 22R
  149. overheating
  150. 84-89 AC unit in a First gen?
  151. 82 weber carb air/fuel tune help
  152. Easy way to tell what your gear ratio is.
  153. Steering play while driving
  154. Cant keep 81 22r idling sometimes.
  155. 75-83 Cab interchange
  156. What Cam should I put in my 22r
  157. Can I put a 85 22r in a 81 82 83 truck with not a lot of problems
  158. 83 pickup wont go into gear. clutch problems maybe?
  159. allowable warpage for the 82 22r head?
  160. Having brake problems with 72 short box
  161. Trailer hitch for '82 4WD Truck
  162. 82 idle and restart issues on new motor and rebuilt carb everyone stumped!
  163. Hi! I'm new here! '83 2wd - 106k miles
  164. 1980 Problem Areas.
  165. Weird electrical problem with new motor on start up.. need some quick help!!
  166. L50 no reverse.
  167. Brake Line Threads
  168. 84 22r into 82
  169. Speeometer Cable?
  170. L50 Help.
  171. wont idle
  172. '81 Yota w/ Weber Passed Oregon DEQ!
  173. my toyota experience begins!
  174. Instrument Cluster Wiring on 79
  175. Stock stereo/radio location ideas.
  176. 4 wire plug on 22r carb
  177. i have a 80 yota and wana no if 36 iroks will fit
  178. Overheating
  179. Radiator Question and interchangability ?
  180. Spring heights
  181. 1979 Truck 20R carb tuning help?
  182. power steering pressure fitting leak
  183. Need a comfortable seat to save my back!
  184. Aftermarket intake manifold
  185. Anyone know what was cut off my axle?
  186. Time for a Head Gasket?
  187. HELP 20r cutting ignition out- im stumped
  188. Idle tends to stick at 2000rpm
  189. '82-'83 radiator question
  190. Need help/suggestions on servicing '80 front end.
  191. Frame swap
  192. 1983 22r throttle linkage.
  193. Got Another Great Deal
  194. dist. not firingon a 22r
  195. First post - looking for a part.
  196. Electric fan thermo sensor questions
  197. Suspension lift
  198. Failed Smog - Gross Polluter - Now What?
  199. Sputtering under load
  200. Vented Rotor Question
  201. The nicest Trekker you will ever see.
  202. 1981 Missing HMM? Dang 22r.
  203. Lugs, lug nuts and wheel bearing dust cap
  204. why does my 83 hilux have Bad compression
  205. 85+ Fuel Tank on a 81?
  206. Stock chrome wheels
  207. heater core replacement
  208. Quick question for 1st gen guys
  209. tach or no tach?
  210. Driveline Yoke Hitting Flange Bracket
  211. 83 grill and light swap?
  212. "Cold natured" 20R??
  213. L43 transmission goes bye bye
  214. Anyone heard of an '83 Mirage?
  215. Help slow truck...
  216. '77 20r starting problems...arrrg
  217. EXTREMELY rough idle, caused be cooling issue?
  218. Installing '80 20R in my '83....couple questions
  219. 1981 pickup.........starter issue
  220. leaking antifreeze.
  221. uh oh, now what? bringing a desmogged truck to california
  222. low range shifting problem 79 4x4
  223. High idle diaphragm problems
  224. coolant temp sender wiring
  225. How to make your '83 yoda 4x4 more quiet - Sound Deadening!
  226. rear springs on front = how much lift?
  227. 22r rebuilt wont start
  228. Best performance for price on 20R?
  229. Rear Output Shaft Seal Removal
  230. Safari Snorkel on a 1st Gen Truck
  231. '79 4x4 turbo diesel
  232. Cursed Ignition
  233. Engine Timing Issue // 20R
  234. Wheel & Tire Suggestions for my '80 4x4
  235. kyb shocks?
  236. Transfer case trouble, I think
  237. 82 Rear parking brake issue
  238. Rear end accident, pic inside
  239. which weber carb to get?
  240. Shock suggestions for '81 DD
  241. engine instalation issues.
  242. 1st Gen Tail Light Fuse Blows Instantly... Please help...
  243. Installed new clutch and now no reverse
  244. Vaccum Mod for 22r
  245. 1983 Transmission / Transfercase Skid Plate
  246. Investing $2,000 in the ol' Rig
  247. 80 truck / 20R Piston, Pin, & Rod Question
  248. 81 pickup has transmission noise
  249. Rebuilding L52
  250. 83 Automatic
