Pre 84 Trucks 1st gen pickups
Idle tends to stick at 2000rpm
Old Jul 9, 2011 | 03:37 PM
snailwagon's Avatar
I have a 1981 Dlx 4x4 pickup. Engine compartment is all stock, california smog spec 22r. When the throttle is gassed, the idle will settle and stay at about 2000rpm. When you stop, it will take about 5 seconds to go back to the normal 700rpm. If revved to say 4000rpm, it will go back down to about 2000rpm and stay for a few.
I've tried two different carbs, can't find any vacuum leaks, and the throttle linkage and cables are smooth.
The carb I have on now is brand new. Besides this issue, the truck runs and starts great. IT will hold very steep angles without stalling and has great response on the entire curve.
Of note, the VCV on the side of the carb is suspect and makes a farting noise when accelerating. Toyota no longer carries the part.
Any suggestions where to look now? and how the heck to I check the function of the dash pot?
Blamalam
Mar 12, 2022 07:34 AM
JHalcyonM
Mar 6, 2019 08:37 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Sarcazmo
Aug 15, 2015 08:22 PM
calderp
Jul 27, 2015 09:58 AM
