Pre 84 Trucks 1st gen pickups
Firewall Gromets
Old Oct 3, 2011 | 12:01 PM
541SR5's Avatar
Firewall Gromets
Does anyone know where I can find new rubber gromets where there wiring harness comes out of the firewall? Over the years mine have become brittle and worn out and I'd like to replace them. Thanks!
Old Oct 3, 2011 | 04:56 PM
slacker's Avatar
problem with that , is they are not "split" gromets , they are installed on the harness at time of manufacture .. so unless your going to cut the harness and splice it back together ? it's not possable to replace them
Old Oct 3, 2011 | 08:22 PM
SoCal4Running's Avatar
Try Lowe's or HD, go to the hardware isle and look in the trays full of little goodies.
Cut the grommet with wire cutters and fit around wire bundle and then into the hole. Put the slice "up" on the top. Even being cut the proper sized grommet with fill the hole snugly.
Old Oct 4, 2011 | 02:10 AM
suncomb1's Avatar
Ron Francis Wire Works has the right size grommets but you will have to split them. There are a number of street rod vendors that have billet aluminum units that are designed to go over the existing wiring harnesses but they are expensive.
Old Oct 4, 2011 | 04:33 AM
dropzone's Avatar
Fossilized
My local Ace hardware has a grommet section that puts Lowe's to shame..
Old Oct 4, 2011 | 04:52 AM
waskillywabbit's Avatar
JEGS and Summit Racing have grommet kits with multiple sizes and styles. Cheap and good for all sorts of applications.
:wabbit2:
Old Oct 4, 2011 | 06:43 AM
slacker's Avatar
geeezz louise .. thats exactly what I was thinking on the first post , but I guess I didnt "say" it right ..
cut the grommet
Old Oct 4, 2011 | 06:56 AM
JustDSM's Avatar
Another option might be to look in some junk-yards for Tacoma's. They've got a nearly identical grommet on the firewall.
Old Oct 4, 2011 | 07:15 AM
irab88's Avatar
http://www.mcmaster.com/#push-in-grommets/=ecfmkc
cheap, fast shipping. i've done business multiple times before with them, and it's top-notch
Old Oct 4, 2011 | 02:43 PM
541SR5's Avatar
Thanks for the responses guys. I figured I would have to split the new grommet to make it work. As long as they fit snug then they will look way better than the brittle, squirrel chewed up originals.
Old Oct 4, 2011 | 02:54 PM
TylerH's Avatar
i will also have to second this post. Great Company. They sell pretty much anything.
TheBFA
Feb 15, 2020 06:55 AM
Lons81
Nov 23, 2015 09:25 AM
SCZIG
Sep 20, 2015 09:00 AM
Duppie007
Aug 20, 2015 04:39 AM
daddio
Aug 9, 2015 07:17 PM
