Pre 84 Trucks 1st gen pickups
Manual Locking Hub Question
Old Oct 5, 2011 | 05:59 AM
southernZ's Avatar
The hubs on my '80 are "ASCO" brand. This is not a OEM hub correct? I thought "AISIN" was the only OEM hub that came on these trucks. I am basically just looking to see if anyone can verify this to me. If so, I will pull the AISIN hubs off of my '83 parts truck to replace the ASCO ones currently on it. (I am servicing the front axle on the '80 right now and want to go back as original as i can)
Thanks,
Stephen
Old Oct 5, 2011 | 06:35 AM
waskillywabbit's Avatar
ASCO pre AISIN. Same hub different labeling.
:wabbit2:
Old Oct 5, 2011 | 06:47 AM
southernZ's Avatar
I literally just got done reading your write-up on the 84-85 forums and read that.......So i guess these are the Original hubs. I guess ill be staying with the ASCO's. Thanks man!
Old Oct 5, 2011 | 06:50 AM
tj884Rdlx's Avatar
ASCO = Aisin Seiki Corp.
ASCO hubs were used on 80-81 trucks so sticking with them is correct for the truck, and it appears they should be blue dial rather than red. parts are interchangeable with the AISINs if you're rebuilding.
Old Oct 5, 2011 | 07:28 AM
They were originally a "Ford" blue from the ones I've seen.
:wabbit2:
Old Oct 5, 2011 | 07:47 AM
dropzone's Avatar
Fossilized
Actually I believe the ASCO hubs were 79-80, not 80-81.
Old Oct 5, 2011 | 11:31 AM
southernZ's Avatar
Thanks guys! What kinda paint are yall using for these? How is it holding up?
Old Dec 17, 2011 | 04:04 PM
Phessor's Avatar
My 1989 HILUX came with ASCO hubs, I have then in front of me getting greased as we speak.
Phessor
Old Dec 17, 2011 | 04:15 PM
I bet you got ASCO dials off a SFA on IFS hub bodies.
:wabbit2:
Old Dec 17, 2011 | 05:29 PM
Phessor's Avatar
Mine is still an IFS truck.
http://www.flickr.com/photos/29870693@N03/6407193195/http://www.flickr.com/photos/29870693@N03/6407193195/ by http://www.flickr.com/people/29870693@N03/, on Flickr
So who knows when they actually found their way on my truck.
Phessor
Old Dec 17, 2011 | 05:50 PM
Weigle's Avatar
Are the AISIN/ ASCO hubs better than new WARN replacements or is there any difference at all?
Old Dec 17, 2011 | 06:09 PM
dropzone's Avatar
Fossilized
Warn toyota replacement hubs do not have a good reputation. you are much better off with a set of stock Aisin hubs
Old Dec 18, 2011 | 12:10 AM
tweek's Avatar
Yup, i have ASCO on my 79'.
Old Dec 18, 2011 | 05:31 AM
Front flex by Phessor, on Flickr
Phessor
Let's see a pic of the hubs.
:wabbit2:
glowz825
Jan 25, 2022 09:28 AM
oldirtydirt
Feb 23, 2020 09:30 AM
deepmarsh
Aug 6, 2015 03:44 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
ItsJustD
Jul 7, 2015 07:49 AM
