Pre 84 Trucks 1st gen pickups
83 grill and light swap?
Old Jun 18, 2011 | 10:02 AM
oldschooltoyz's Avatar
Just bought an 80 long bed,and am interested in swapping grill and headlights to that of an 83.Is it possible and how difficult would it be?Thanks for any help.
Old Jun 18, 2011 | 02:45 PM
83's Avatar
83
It's possible and it's easy. Search.
Might or might not have to do some very minor drilling or bolt something on, and the wires connections are different, so you'll need to do a little splicing to get the lights next to the headlights to work. I'd cut that part off the 83 too while you're getting the grill and headlights.
Old Jun 18, 2011 | 03:02 PM
Crimson Yota's Avatar
Not trying to thread jack, but does anyone know if an '82 grille will work with these light bezels? http://cgi.ebay.com/ebaymotors/HEADL...Q5fAccessories
I want the round lights with the newer grille. Thanks.
Old Jun 18, 2011 | 06:17 PM
dropzone's Avatar
Fossilized
no they won't. you end up hacking the grill...looks like crap. find a 79-81 grill if you are going that route.
to the OP here is a write up that was done by one member..it can work for converting your round to rectangle:
Originally Posted by ocdropzone
OldDirtyDirt did a nice write up on converting square to round headlights
This can be used to go round to rectangular too..
Parts you will need:
-two headlight aprons (doors, bezels) of the kind you want
appropriate grill (79-81 grills are not compatible with rectangular headlight -aprons and vice versa with out hacking stuff up)
-2 headlight buckets (round or rectangular)
-side marker lenses (again they are specific to the headlight style)
-head light lenses assemblies (now is a good time to updgrade to H4 style housings)
Side marker lights will need plugs swapped:
Old Jun 18, 2011 | 06:55 PM
83's Avatar
83
Yep.
If you've done any work at all to your truck, house etc., what needs to be done for this swap will be obvious and easy once you get into it. No problem.
Old Jun 19, 2011 | 10:49 PM
SC81YOTA's Avatar
I was lucky enough to have both model trucks sitting there next to each other. I made a templet out of card bord and the 82-83 model has the same bolt holes for each model. Just mock it up and punch some holes. I kept my templates just for it!!
Flying91
45
Apr 11, 2024 04:39 PM
ashersullivan88yota
Jan 18, 2022 05:37 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
lledwod
Aug 30, 2016 01:03 PM
Johntom240
7
Jul 13, 2015 12:18 AM
