Pre 84 Trucks 1st gen pickups
Time for a Head Gasket?
Old Jul 14, 2011 | 08:43 AM
Magnum Johnson's Avatar
Ok, so I spent my last two days off doing some preventative maintenance on my 81' now it seems I created a problem. I replaced the worn out timing chain etc, front cover gaskets, water pump, oil pan gasket, belts, alternator (gm 100a), and installed my electric fan. I was a little worried about the timing setup but she started rite up and is running better than ever, BUT now I discovered an oil leak rite at the spot where the hidden bolt is. I did have a hard time getting the hidden bolt back in place because the head gasket was kinda covering the hole (Im thinking a layer of it folded under itself).
So now that I created this awesome oil leak im thinking I should just bite the bullet and replace the head gasket rather than pulling the timing cover back off only to confirm that the head gasket was damaged by the cover. Any thoughts or suggestions?
Old Jul 14, 2011 | 09:04 AM
snobdds's Avatar
I could not agree with you more. Your going to have to bite the bullet and replace the head gasket. Go OEM with the Head Gasket from the dealer too.
It is almost impossible to replace the timing cover without crimping the HG. I've learned my lesson with that job...just do it right and remove the head. Less time and fuss in the long run.
Old Jul 14, 2011 | 09:15 AM
cman1's Avatar
DITTO!!!! ive got a nice 3drip a day leak from the same thing.sometimes quicker and easier bites ya in the ass.
Old Jul 14, 2011 | 09:48 AM
Ok, thats what I figured, at least im not alone! I think I will pick up the felpro Head Gasket kit from rockauto then supplement it with an oem toyota head gasket. Unless the felpro HG is worth a damn...
Old Jul 14, 2011 | 10:58 AM
83's Avatar
83
I'd use the OEM..
Old Jul 14, 2011 | 11:10 AM
Terrys87's Avatar
I have done the same thing with the cover. I have seen it done without pulling the head.
Now I just pull the head, saves alot of trouble in the long run. You can get everything checked and cleaned up nice.
bigjstang
Jun 2, 2025 03:56 PM
Whatever123
Sep 30, 2015 12:12 AM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
