Pre 84 Trucks 1st gen pickups
Oil spewing from the block
Old Oct 3, 2011 | 06:44 AM
Padawon's Avatar
Make a long story short…
I bought a 1982 22r long block from an engine builder and behind the passenger side engine mount bracket there is a threaded hole in the block where something (a plug) is missing and oil is coming out of the hole. Unfortunately I don’t have any idea or pictures of what goes into that hole.
I didn’t run the engine like this.
Can someone help me out?
Old Oct 3, 2011 | 07:05 AM
waskillywabbit's Avatar
Oil pressure sending unit installed?
:wabbit2:
Old Oct 3, 2011 | 07:12 AM
xxxtreme22r's Avatar
Oil filter is on that side in that area as well, just sayin. I do believe there is also a second plug just forward of that oil filter and oil pressure sending unit. But I am not 100% sure on that. I remember a while back someone saying something about being able to remove a plug in an oil passage that you can use instead of teeing off the oil pressure sending unit.
Old Oct 3, 2011 | 07:18 AM
Padawon's Avatar
I don’t think the sending unit or the filter would fit behind the engine mount bracket, Behind the bracket as in directly behind the bracket in between the four engine mount bracket mounting bolts that mount the bracket directly to the block… Should have got a pic of it.
But yep, even got a Toyota oil filter from the dealer. Oil pressure and filter are in
Old Oct 3, 2011 | 07:20 AM
see my last edit, that might be what I am talking about with the second plug/port. If so nothing but a plug goes in there.
Old Oct 3, 2011 | 07:29 AM
Padawon's Avatar
This is what I was thinking and hoping. The one picture I took of this area when I pulled my engine didn’t turn out.
Old Oct 3, 2011 | 10:31 AM
83's Avatar
83
Yeah there are a few plugs that take a hex-nut style plug along the side of the engine that go along oil galleys. A photo would help, but I'll bet that's all you're missing.
Old Oct 4, 2011 | 09:43 AM
Padawon's Avatar
It was this chingadera…..
Drove up to toy connection in Santa Clara and they hooked me up with one.
Old Oct 4, 2011 | 01:40 PM
83's Avatar
83
Awesome
Old Oct 5, 2011 | 06:20 AM
Padawon's Avatar
http://www.youtube.com/watch?v=m3DgSLs9C48
Ok so now oil galley its fixed but I have an issue when its running.
She fires right up and its freaking awesome... but has Idle surge and drops back down to an almost stall then it surges back up.
Vacuum line, carb, ignition problem?
I was going to start build thread last night but my internet service was down. Probably becouse the PGA is in town and they redirected all the bandwith to the rich people!
Old Oct 5, 2011 | 06:34 AM
wow never seen a 22r do that. Only a 22re. Maybe a fuel supply issue. Could be vacuum leak.
What is the fuel level in the carb doing? It almost seem like the fuel bowl fills up and then empties when the engine revs down it uses less fuel so fuel bowl fills back up allowing the carb to supply more fuel and thus revs back up.
As I said, I never seen that before so this is only guess work on my part.
Old Oct 5, 2011 | 07:35 AM
Padawon's Avatar
I will have to look at the float level. Would Vac advance or HAC cause this?
I might by pass the HAC and see if it could be the culprit. Also the PO had the Distributor vac hoses the opposite of the Haynes manual and opposite of under the hood sticker (can barley read it)
Old Oct 5, 2011 | 07:58 AM
I doubt it, but anything I say is pretty much guesswork at this point with it. You do have it timed to 0 degrees with vac advance off right? I doubt a timing issue though would cause that.
Old Oct 5, 2011 | 08:17 AM
Padawon's Avatar
Well.. Setting the timing was going to be the next step. Ill pull the vac advance and see what it does too.
Old Oct 5, 2011 | 08:00 PM
Padawon's Avatar
On 1982 22r. The air cleaner housing has two items built into it that need to be hooked up; MC valve and Thermo Valve. I didn't have it hooked up when it was on the first time.
At least I didn't mess anything else up trying to diagnose the issue.
bigjstang
Jun 2, 2025 03:56 PM
dumpster84
Apr 30, 2016 06:03 AM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
Coreyr384
Jul 10, 2015 11:13 AM
