Pre 84 Trucks 1st gen pickups
Quick question for 1st gen guys
Old Jun 19, 2011 | 12:57 PM
Crimson Yota's Avatar
I'm trying to remove my passenger seat, I've got all the bolts out except the rear drivers side one:
Does anyone know how to remove this one? theres not enough room to use a socket, the angle is too weird to get at it with wrench, and a pair of needlenose pliers arent doing the trick..
So what are your guy's methods for removing this one??
Thanks
Old Jun 19, 2011 | 01:27 PM
4x4climber's Avatar
slide the seat forward... sockets work good. i usually take that one out first...mainly cuz it wont move without all the bolts in..
Old Jun 19, 2011 | 02:27 PM
Sparkys83yota's Avatar
i was replacing my seats and had the same problem. The seat was stuck and would not slide forward. I ended up taking a sawzall from underneath of it. It was not long after that I had complete access to it.
Old Jun 19, 2011 | 05:00 PM
slacker's Avatar
soak your seat track in "viner schlider" . it is not moving all the way .. and you'll need to free it up to remove that bolt ..
Old Jun 20, 2011 | 03:38 PM
Robs Toynado's Avatar
Hey if those dont work the wire underneath that connects the slider adjustment might be missing. Then youll have to hold it while you move the seat. I had same problem. Depends on what side of the seat it is. Just a thought!
Old Jun 21, 2011 | 07:11 PM
SC81YOTA's Avatar
This is most likely the problem
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
coryc85
Jul 6, 2015 04:07 AM
CJ94yota
Jul 3, 2015 10:14 PM
