Pre 84 Trucks 1st gen pickups
Tranny issues
Old Sep 19, 2011 | 06:28 PM
STUMPJUMPER87's Avatar
Tranny issues
OK guys i got a problem. Tranny is actin up and i need to know why, i have 1st gear about half way through 2nd it peters out third i get a bad vibration that will shake the teeth outta your skull, fourth is a joke it has no power or anything, and good luck getting it in to 5th I NEED HELP QUICK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! This little truck is my baby and wifey says if i dont get it running soon its goin to scrap yard!!!!! Not happening!
Old Sep 21, 2011 | 10:14 AM
enigmaT120's Avatar
Is it making a lot of noise from the gearbox or what? I think these trucks are worth at least a junkyard replacement gear box, if it comes to that. I want to rebuild mine.
Old Sep 21, 2011 | 10:27 AM
83's Avatar
83
Yeah I think a better description would help. From your post, I'm not even sure I'd call this a tranny problem. Hard to say exactly what you're getting at, but it sounds like a combination of possibly being undergeared for your tire size, possible need of a tune up, and driveshaft out of phase.
But not knowing even the basics about your truck, it's hard to say...what's your tire size? Stock engine? How many miles? What have you done to it lately? Is it new to you? etc etc etc
Old Sep 21, 2011 | 09:27 PM
vkasm1's Avatar
doesnt sound like trany but need better discription of problem.
Old Oct 2, 2011 | 07:23 PM
Ok guys figured it out its the clutch but i have no clue on how to change them. are they hard to do? Im not very mechanical but im gonna have to be since a shops gonna charge me 450 -700 buck to do it!
Old Oct 3, 2011 | 06:20 AM
83's Avatar
83
It's not complicated, it's just a pain. Search, it's definitely been gone over before.
Basics: get a friend, or two. Remove driveshafts, remove clutch slave cylinder, disconnect electrical (reverse light, 4wd indicator), remove all the bellhousing bolts, including the ones in the starter, get under it, or get a jack under it, and remove the crossmember and drop the whole thing. the other way would be all the first stuff, but don't take out all the bellhousing bolts until you unbolt the crossmember from the t-case. Get the crossmember out, then get under there (two under there is better), and have someone get the bellhousing bolts out, then drop it all.
You'll need a couple people under there, gently (or not so gently..) rocking the whole tranny back & forth to get the seal to break. You'll know when it does. Pull it back (towards back of truck) when you can feel that it's broken free. You need to get the input shaft out of the clutch. Then gently lower it to the ground.
Get a good clutch, not a autozone one.
Learn how to use the clutch centering tool. Simple, but important.
Hook everything back up.
Oh, and get the flywheel resurfaced while you're in there.
It's a pretty crappy job the first few times...after my...probably 5th time doing it, it went super smooth and I wondered why I used to complain about it so much, but it's just a heavy piece to have to be working with. It's also the first major work I had ever done on my truck. Get someone to help you who has done it before.
Old Oct 3, 2011 | 10:36 AM
83's Avatar
83
Oh, and "not very mechanical" and "first generation toyota truck owner" (you never mentioned what year your truck is...), don't really go together, unless you have a lot of money to be handing over to mechanics.
Old Oct 3, 2011 | 10:57 PM
ok its an 83 toyota shortbed 4x4 and i prolly will turn it over to a mechanic but wheres a decent clutch for these things? i work for an autozone so that was my 1st guess for ordering one. where can i find a good one?
Old Oct 4, 2011 | 06:11 AM
83's Avatar
83
Well, just do a little research on what brands are good. I'm guessing you can get a good one through autozone, just don't get whichever one they would have on the shelf. LUK are good, and I believe are often OEM. Marlin Crawler has a really good clutch. Those are the only two I really know of, but if you do some searching, you may find more. A lot of shops won't let you hand them your own part, though. You might be able to ask that they use OEM quality parts, but I doubt they'd take a part you bought and put it in the truck. Most won't, anyways.
Old Oct 4, 2011 | 09:05 AM
Jkelley429's Avatar
get a stock toyota/aisin clutch. best choice for long life. if youre looking for high performance check out marlincrawler.com
Dieselmann
Feb 19, 2019 02:57 AM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
yourrealdad
Jul 21, 2015 11:13 AM
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
