Pre 84 Trucks 1st gen pickups
81 22r No spark
Old Oct 19, 2011 | 06:05 PM
Romans117's Avatar
81 22r No spark
No spark, No blinking light from timing light when turned over on any plug wire. Everything specs out with coil, igniter, pick-up coil, distributor turns when cranked. Rotor turns clockwise and springs back, no slop in distributor shaft
Fuses under dash look good. There not many of them. Where would others be? Ideas?
Old Oct 20, 2011 | 06:11 AM
83's Avatar
83
There is some relay in the distributer that can go bad. It'll turn either way since there's a gear going into the cam. If you have a service manual it may tell you how to test it. Beyond that, I'm not sure...
Old Oct 22, 2011 | 05:10 PM
Romans117's Avatar
Need advise!!!
Old Oct 24, 2011 | 10:27 AM
peow130's Avatar
getting power to the igniter?
getting power to the dizzy from the igniter?
all you need for spark is a 12v constant power source, and if youre not getting it, then something is wrong with either the coil, or the distributor, or the wiring..
Old Oct 24, 2011 | 01:40 PM
shady4420's Avatar
How do you know the coil etc. is good? have you checked the relays? let us know how you checked what you checked and get a service manual, they'll be a life saver for many problems down the road.
Old Oct 26, 2011 | 03:21 PM
Romans117's Avatar
The dizzy turns, cap and rotor is new, power to igniter, power from the igniter. I tried a new coil. I have the service manual. I ohmed the components as directed. I replaced the pick-up coil. No spark from coil.
There are no other relays I am aware of other than the dash fuse for engine. I have looked in the service manual for other relays or fuses and see nothing. I will look again.
Old Oct 26, 2011 | 09:34 PM
1stgenboy's Avatar
I had this problem where the igniter, dizzy and coil all ohmed out correctly and no spark....I found a good dizzy and igniter on craigslist and stuck them in and no problem....
Old Oct 27, 2011 | 04:16 AM
Romans117's Avatar
"No blinking light from timing light when turned over on any plug wire."
Focusing on the wiring between the Distributor and Igniter.
Old Nov 13, 2011 | 09:47 AM
Romans117's Avatar
Wiring is good. The transitor did not test out. Will replace and report back.
Old Nov 26, 2011 | 06:49 AM
Romans117's Avatar
The igniter was the problem.
Old Nov 28, 2011 | 06:14 AM
83's Avatar
83
Good work! That's what my problem was when I had no spark. I would have mentioned it but you said in your first post that it tested out ok.
They're pricey little things!
1uzRunner
63
Nov 10, 2018 03:58 PM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
ac7822
Sep 12, 2015 06:57 PM
EatChipsNow
Sep 9, 2015 01:25 AM
anniesball
Sep 7, 2015 11:20 AM
