Pre 84 Trucks 1st gen pickups
Easter egg hunt: where is the headlight fusible link on an 80 pick up
Old Oct 19, 2011 | 09:00 PM
cruiserjim's Avatar
where is the fuseable link for the headlights on a 80 p-u
Old Oct 19, 2011 | 11:52 PM
dropzone's Avatar
Fossilized
good question...i should figure out where mine is on my '81.
dunno how much the wiring changed between the 80-->81 but here are some pics of my 1981 wiring diagram that might help...
Old Oct 20, 2011 | 02:46 AM
suncomb1's Avatar
There is no headlight fusible link. There are 3 fusible links at the positive battery terminal that protect the Ignition switch circuits, Charging circuits and the Constant Power Circuits. The headlights are protected by a fuse circuit in the fuse box-left of steering wheel under the dash.
Old Oct 25, 2011 | 12:26 PM
cruiserjim's Avatar
80 headlights only work all the time
I traced the power back to the headlight switch from the fuse after repairing the factory wiring but only have high beams.I know someone else has had this problem , what was the fix and does anyone have a schmatic isolating just the headlight circuit?
Old Oct 25, 2011 | 02:39 PM
suncomb1's Avatar
Head Light Relay power feed to fuse panel-Red, fuse panel to LH headlight-Red /White and to RH headlight-Red /Black. High Beam on headlights to Dimmer switch-Red /Green, Low Beam on headlights to Dimmer switch-Red /Yellow. Head light relay power feed to relay contact and coil + Red /Blue, Head Light relay coil - to Light Control and dimmer switches-Red /White. Note: The dimmer and light control switches switch neutrals / grounds not hot (12V+).
80Truck
Oct 12, 2025 07:25 PM
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
mldave
Aug 10, 2015 09:23 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
