Pre 84 Trucks 1st gen pickups
Clutch quit working
Old Nov 9, 2011 | 04:55 PM
robertm's Avatar
Clutch quit working
My pickup is an 81 2wd with 22r and 4 speed transmission. I drove it last week and everything was fine. I got in it on Monday and immediately the clutch didn't feel quite right. Didn't seem to have as much pressure as it should have. I drove it about 15 miles and it steadily got worse. Got ready to come back home in it and the clutch only worked once or twice. I was able to make it back home. Seems to have gone from working to gone in about 30 miles. as it was quitting, it kept losing pressure and more pressure in the pedal. I hope its nothing major, I hope its the master or slave cylinder. Where should I begin? any suggestions are appreciated. thanks
Old Nov 9, 2011 | 05:45 PM
dropzone's Avatar
Fossilized
inspect your lines and both cylinders. when it happened to me it was the slave cylinder.
Old Nov 9, 2011 | 06:23 PM
jason191918's Avatar
x2. Check the fluid. If it is low, either a leak or bad slave. If no leak, probably master.
Old Nov 10, 2011 | 04:27 AM
robertm's Avatar
Thanks! That's what I was hoping to hear!
Old Nov 10, 2011 | 04:40 AM
white yota 4x4's Avatar
same thing happpened on my mud yota and it was the slave cylinder it not but like 15 bucks and every easy to change!!!!
Old Nov 10, 2011 | 04:42 AM
lifting my yota
hey guys if i put a 2" lift on my yota do i have to put those bars that go from the frame to the rear axle???
Old Nov 10, 2011 | 05:07 AM
Jkelley429's Avatar
mine did the same thing, and i also drove it like that. i ended up having to replace the clutch because it wasnt grabbing and stripped the clutch out. i would check that. i replaced my slave cyl. and tried to drive it and the clutch was slipping and didnt pull.
Old Nov 10, 2011 | 08:17 AM
funcrazy1's Avatar
I had to replace my master and slave cylinder for my clutch
Old Nov 11, 2011 | 05:51 PM
robertm's Avatar
Thanks for everyone's help. Turns out the master cylinder was bad. I guess the master cylinder was the problem all along, but now the master and slave have been replaced. Hopefully I'll have no more issues for a while. thanks again!
Old Nov 11, 2011 | 06:26 PM
Jkelley429's Avatar
glad you got it worked out. it couldve been alot worse
Old Nov 11, 2011 | 06:54 PM
BMcEL's Avatar
Reminds me of when I drove my '80 to work one day and the master decided to blow a seal and dump the fluid on my feet...20 miles of grinding gears and rolling up to red lights real slow lol.
Got to work and had to stop at the end of the 1/2 mile drive to open the gate.
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
Nickdigg
Jul 7, 2015 06:04 AM
Suprarossa
Jul 6, 2015 05:21 AM
