Pre 84 Trucks 1st gen pickups
low range shifting problem 79 4x4
Old Jun 12, 2011 | 08:57 PM
bushrider's Avatar
i have a 79 4x4 pick up, when ever i use low 4x4 in 1st gear and try to shift into 2nd gear in low it kicks the transfer case into neutral, the 2 shifters are contacting each other. do all these old trucks do this?is there a way to fix this problem, perhaps a kit that has different angle shifters or some thing?
i allready put new bushings in the shifter to toghten it up a bit thinking that was cousing it but its still kicking it out
Old Jun 13, 2011 | 04:47 AM
waskillywabbit's Avatar
Got a body lift?
Moved to right section.
Welcome to YT.
:wabbit2:
Old Jun 13, 2011 | 06:36 AM
blake.nemitz's Avatar
i bet your tcase shifter is in backwards, or like wabbit said a body lift will make your boot push and pull on each other due to a longer shifter throw
Old Jun 13, 2011 | 07:00 AM
dropzone's Avatar
Fossilized
If you have an L43 4 speed side shifter, it is usually kind of sloppy. I used one for about a year. Ended up dog legging a TC lever to avoid a similar issue.
Edit- here is a pic to give you an idea of what I did. Used it with my 5 speed too till I found another lever:
Originally Posted by ocdropzone
so as an interim fix until I have some more time to remove the shift lever thingy from underneath I used the extra TC lever I had and a $1 unknown shifter from the U-Pull it and dog legged the front TC lever...no more getting knocked out of low range:
might need to shorten the dog leg a little bit, but this will work for now...thought it might hit my leg while driving but a trip around down it seems fine.
Jnkml
Jul 6, 2015 01:20 PM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
zd92655
Jul 5, 2015 04:25 PM
