Pre 84 Trucks 1st gen pickups
Gaskets on either side of carb spacer
Old Nov 27, 2013 | 11:30 AM
83's Avatar
83
Use them? You know the plastic heat spacer that sits under the carb? When I took off my old carb, there were no gaskets on either side. No leaks. But since I had the gaskets with my rebuilt carb...I figured I should use them. Now I have a leak at the base of the carb.
I figure it could just be that I need to tighten it down more, but I have it pretty tight...
I know the spacers Toyota sells for 79-83 trucks come with gaskets glued on to both sides. But Toyota doesn't even sell the spacer for a 78.
So...Think I just need to tighten the mounting bolts down a bit, or should I just ditch the gaskets?
Old Nov 27, 2013 | 11:41 AM
catfish21's Avatar
Man I say go with what works if it worked before go with it you have a stock carb or weber
Old Nov 27, 2013 | 11:46 AM
83's Avatar
83
Stock
HighLux's Avatar
gasket ftw
Old Nov 27, 2013 | 12:03 PM
83's Avatar
83
Ok.
So probably just make sure it's super tight...I'm afraid of cracking the spacer, especially since I know they don't sell them anymore.
Old Nov 27, 2013 | 12:46 PM
81 Toyo's Avatar
I used both of mine with the rebuilt carb install, I figured if it came from the factory already attached to the spacer than they should be used.....make sure all surfaces are flat and no burrs or old gasket stuck to it. If the leak continues wouldn't hurt to put a light coat of Permatek gasket sealer on each side of gaskets to help seal tight.
Old Nov 27, 2013 | 12:57 PM
83's Avatar
83
Ok, thanks.
I just checked it out again on my break. Apparently when I said I had it pretty tight, what I meant was that I thought I had it pretty tight.
I went around to each of them a couple more times and tightened them up. I didn't have time to start it up and check for leaks again, but it definitely wasn't as tight as I thought it was.
Hopefully that fixes it...
It was driving me crazy that it started right up with the new carb, but wouldn't idle!
Old Nov 27, 2013 | 02:23 PM
gillesdetrail's Avatar
From experience, too tight can also cause leaks, I suggesting tightening to shop manual specs. Silicone rtv can also save you some trouble but you shouldn't have to use it.
Old Nov 27, 2013 | 04:46 PM
83's Avatar
83
Ok. Well, how it was before tightening it...it leaked. With it as tight as I feel safe going, it still leaks. So I guess I'll take it back off this weekend and see if there's something keeping it from getting a good seal, and use some Toyota FIPG while I'm at it.
Sep 4, 2015 09:27 AM
Yota.Jay
Jul 23, 2015 08:08 PM
smiley52
Jul 11, 2015 05:16 AM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
