Pre 84 Trucks 1st gen pickups
Oil drain plug problem. Need advice
Old Oct 27, 2013 | 04:59 PM
Shaun Crystal Gomban's Avatar
I changed oil on my truck for the first time and now my drain plug drips. I redrained and inspected the Threads. The bolt is fine but upon inspecting the drain hole I noticed a section of thread completely gone. It's about a quarter inch high and 1/16 inch wide. It's a uniform and clean area without thread so I thought it maybe supposed to be like that. But it appears my drip is from that point. My local napa said they don't carry a oversize plug for the 22r's 18mm plug. Is that threadless area normal? Anybody experienced this and know how to fix? It drip frequency is too frequent for comfort. Above the threadless area I can see the threads go completely around in the pan drain hole.
Old Oct 27, 2013 | 05:15 PM
SoCal4Running's Avatar
Go back to napa and get a oil plug gasket. Their needs to be a fiber gasket there to seal against the pan.
Old Oct 27, 2013 | 05:32 PM
Teuf's Avatar
I 2nd the gasket. And how about draining and then cleaning the threads, apply then some type of gasket sealer. Just a thought.
Old Oct 27, 2013 | 05:44 PM
When I removed it it only had a small brass/copper looking washer on it. Napa did give me a hard compressed paper type gasket that she said was for 18 mm but it didn't fit at all. Much too small. I'll try a different store tomorrow for the proper gasket.
Old Oct 27, 2013 | 06:41 PM
83Toyota88's Avatar
Boom:
New drain plug - http://www.lceperformance.com/Oil-Pa...-p/1013114.htm
New drain plug gasket - http://www.lceperformance.com/Gasket...-p/1013115.htm
Old Oct 27, 2013 | 06:59 PM
Thanks for your guys insight! I had some rtv oil resist gasket maker and it worked fine. Learning everyday
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Gamble_STi
Jul 7, 2015 07:54 PM
