Pre 84 Trucks 1st gen pickups
charging issue???
Old Aug 20, 2012 | 02:50 PM
ydopen's Avatar
charging issue???
I dont drive the 83 much but make it a hbit to crank it every 2 weeks and take it down the drive way, That being said about a year ago the alternator crapped out, so i changed it, The battery lite was still on after the change, Called my mechanic buddy and he said keep a eye on it but there could be something in the alternator thats bad that makes the lite come on?
Its cranked and ran fine since the swap a year ago, last week i went to crank it and the battery was dead? Jumped it off and it did fine cranking afterwords, Wanting to run it a little I decided to take it to work= a 30 mile run, It ran fine half way there then the lights started dimming out and i costed into a gas station.
Battery dead and the yellow wire that runs to the battery on the positive side was melted?
Old Aug 21, 2012 | 04:22 PM
ydopen's Avatar
Hmm? Could it of been over charging? thats what burnt the yellow wire? What is the Yellow wire?
Old Aug 21, 2012 | 04:54 PM
slacker's Avatar
yep .. sounds like the regulator to me .
could also be a faulty "wire" from before ? so I would replace the fuse wire check voltage from alt , and go from there
Old Aug 22, 2012 | 03:34 AM
ydopen's Avatar
so the yellow wire at the battery runs to the alternater and will need to be replaced?
80Truck
Oct 12, 2025 07:25 PM
bigjstang
Jun 2, 2025 03:56 PM
nvdesertrunner
May 11, 2020 08:18 PM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
mr_manny
Jul 31, 2015 10:39 AM
