Pre 84 Trucks 1st gen pickups
Best method for gear reduction?
Old Dec 11, 2011 | 09:13 AM
Weigle's Avatar
I have an '82 truck with 4.11's, an L45 transmission, 32" tires, and a RF1A case. I feel like its geared too high, even in 4-low I would like it to crawl slower so I don't have to ride the clutch.
I'm thinking the most cost-effective way to achieve a reduction would be swapping the 4.11's out for a set of 5.29's. It is my daily driver; however, I don't need to go fast nor do I mind taking off from a stop sign in second-gear.
Your thoughts?
Old Dec 11, 2011 | 09:27 AM
Teuf's Avatar
Hello Weigle, and welcome. I think 5.29/32's is a stretch. What is your tire size upgrades down the road? If they are just 32's I would go with 4.88, thats plenty low.
Old Dec 11, 2011 | 09:38 AM
Weigle's Avatar
Probably going to keep running 32's but MAY run a 33... Not too much difference between the two. I have no long-term goals other than to maintain somewhat of a stock appearance. It has a 2" lift which I feel is plenty adequate for what I do, which are primarily forest service roads, some in bad condition, creek crossings, ruts, etc...no serious four-wheeling.
There are a few obstacles, mostly a series of rock ledges I have to ride the clutch (if my Weber stays running that is
Old Dec 11, 2011 | 11:09 AM
Teuf's Avatar
Well than 5.29/33's are a reasonable match.
Old Dec 11, 2011 | 10:39 PM
ConSeann3ry's Avatar
dual cases is always an option too if you're mainly just looking for slower crawling...probably a lot cheaper too
Old Dec 12, 2011 | 12:38 AM
Weigle's Avatar
That was my first thought. . . but seems labor intensive and would require me cutting a hole in a rust-free floor
A set of gears would run about $400-$500 if I install them I think. I haven't made up my mind, gotta buy the wife something for Christmas first. . .
Old Dec 12, 2011 | 04:05 AM
dropzone's Avatar
Fossilized
There are triple sticks out there that do no require a second hole:
http://radesignsproducts.com/TripleSticks.aspx
You might want to put some #'s into an online gear calculator, 5.29's and 33's/32's are gonna be screaming at highway speeds.
Ever set up your own gears?? It is kind of an art.
Educate yourself at master Zuk's site: gearinstalls.com
Dual cases will run you about $1k, just tell your wife it is a family gift..
nvdesertrunner
May 11, 2020 08:18 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
norcal98
Aug 10, 2015 06:20 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
sabine
Jul 18, 2015 03:59 PM
