Pre 84 Trucks 1st gen pickups
my 81
Old Oct 28, 2008 | 06:56 PM
scott139's Avatar
my 81
i just did a motor/tranny/tansfer swap everything but the transfer was working before got it all in an cant get fuel to the carb has 2yr old mechanical fuel pump need help
Old Oct 28, 2008 | 07:10 PM
4x4YOTA's Avatar
just keep cranking it has to get the fuel from the tank to fill up the carb I had the same problem with my 82 when I did my enine swap sat for 5 yrs before I swapped in a new engine just had to keep cranking it til if finally fired up...also so starting fluid kinda helps
