Pre 84 Trucks 1st gen pickups
1st gen transfer cases
Old Sep 24, 2008 | 03:14 AM
oztoy's Avatar
I have 3 1st gen transfer cases
2 have sideplates approx.3" x 4" on the l.h.s
1 transfer does not
i'm just wondering if these cases with the side plates were made for a P.T.O outlet or are these a different style of case ie;chaindrive
Old Sep 24, 2008 | 07:26 AM
nico's Avatar
According to Marlin:
Type 1-A Carb 4Cyl
Installed 1979 - 1980
Top Shift
Short Style Case
Short Low Range Shift Rod
C-Clip Retained 2WD/4WD Rod
8 or 9 mm Flange Bolts
Noisy Style Gears (I take this to mean straight-cut gears)
21 Spline "Fuseless" L43-Style Input
27 Spline Outputs
Type 1-B Carb 4Cyl
Installed 1981 - 4/1983
Top Shift
Short Style Case
8mm Flange Bolts
Noisy Style Gears
21 Spline Input
27 Spline Outputs
Type 1-C Carb 4Cyl
Installed 4/1983 - 8/1983
Top Shift
Tall Style Case
8mm Flange Bolts
Noisy Style Gears
21 Spline Input
27 Spline Outputs
Old Sep 25, 2008 | 04:05 AM
oztoy's Avatar
Thanks for the help
I'm going to rebuild one of the boxs but was unsure which would be the better one
4x4-runner
Apr 18, 2017 09:08 PM
4x4-runner
Dec 27, 2016 01:58 PM
Chumlee780
Nov 13, 2015 03:18 PM
yourrealdad
Jul 29, 2015 11:08 AM
crashburnoveride
Jul 10, 2015 06:39 AM
