1st gen transfer cases
I have 3 1st gen transfer cases
2 have sideplates approx.3" x 4" on the l.h.s 1 transfer does not i'm just wondering if these cases with the side plates were made for a P.T.O outlet or are these a different style of case ie;chaindrive |
According to Marlin:
Type 1-A Carb 4Cyl Installed 1979 - 1980 Top Shift Short Style Case Short Low Range Shift Rod C-Clip Retained 2WD/4WD Rod 8 or 9 mm Flange Bolts Noisy Style Gears (I take this to mean straight-cut gears) 21 Spline "Fuseless" L43-Style Input 27 Spline Outputs Type 1-B Carb 4Cyl Installed 1981 - 4/1983 Top Shift Short Style Case Short Low Range Shift Rod C-Clip Retained 2WD/4WD Rod 8mm Flange Bolts Noisy Style Gears 21 Spline Input 27 Spline Outputs Type 1-C Carb 4Cyl Installed 4/1983 - 8/1983 Top Shift Tall Style Case Short Low Range Shift Rod C-Clip Retained 2WD/4WD Rod 8mm Flange Bolts Noisy Style Gears 21 Spline Input 27 Spline Outputs |
Thanks for the help
I'm going to rebuild one of the boxs but was unsure which would be the better one |
