Pre 84 Trucks 1st gen pickups
3/4 ton?
Old Sep 19, 2008 | 11:33 PM
slisdexia's Avatar
Question 3/4 ton?
somewhere I learned that Toyota made the early trucks in 3/4 ton as well as 1/2 using the same body style. I think I may have one because the ride is STIFF, even though my shocks are 25 years old, this thing rides rough and seems like a plank with tires. Any easy way to tell? Or do I have to go to the stealership?
Old Sep 20, 2008 | 01:06 AM
Al's Chop Shop's Avatar
these are pretty much 1/4 ton trucks.
it rides harsh from short springs. no way around that unless you swap to longer springs (IE, chev 63's).
they did make one ton versions though... or at least that's what i've seen on the back of a few pickups some years ago.
Al
Old Sep 20, 2008 | 06:20 AM
slisdexia's Avatar
Oh, ok thanks man. I guess 1/2 was kinda a stupid call on my part
Old Sep 20, 2008 | 07:22 AM
4Crawler's Avatar
Actually the springs are stiff riding because they have sagged with time. When they do that the softer upper leaves in the pack settle down onto the stiffer lower leaves and that makes the overall spring rate higher. In back, your springs are probably riding on the stiff overload leaf (the one that is over 1/2" thick on the bottom of the pack) and that makes things very rough. Likewise, up front (assuming a leaf spring front end), you probably have an inch or so of up travel before hitting the rubber bump stop. That means any bump over 1" tall and the front end bottoms out and that makes for a very rough ride. Finally your spring shackles are likely rusted into the spring bushings and that prevents them from moving freely and that aggravates the rough ride as well.
And there are 1/2-1 ton 2WD pickups, they typically had the dual wheels on the rear axle. Commonly found in chassis form under the little RVs based upon the Toyota pickup.
Old Sep 20, 2008 | 08:10 AM
scuba's Avatar
I used to own a 1ton 2wd.
I had something like 4:47's from the factory
FUN LITTLE MONSTER
i kept up with a crown vic all the way through 4th one time.
And since ive moved back to cali, i cant count how many of the dualies i have seen.
Old Sep 20, 2008 | 12:04 PM
85toy's Avatar
ya there are tons of the old duelys 2wds around here.
Old Sep 20, 2008 | 02:23 PM
nico's Avatar
'83 2WD 3/4 tons exist, but you would probably know if you had one.
Check the Mfr's plate - it should show the GVWR.
Old Sep 20, 2008 | 03:21 PM
toydp1224's Avatar
i have a 1990 toyota 2wd 22re and i have put over a 1/2 ton in it and it did fine
Old Sep 20, 2008 | 05:36 PM
slisdexia's Avatar
hmmm, now I really feel like a newb(I know, I am one too) check the GVWR!
Old Sep 20, 2008 | 07:24 PM
jsn_stockard's Avatar
The title to my 92 4x4 says it is a 3/4 ton. Many people don't believe this but I will post a picture on here of the title when I am home.
Old Sep 20, 2008 | 08:08 PM
rowdy235's Avatar
first-gen 3/4 tons are pretty cool, beefed up suspension, etc. 2wd long box only though, a teacher at my school has one.
MichaelKLerner
Oct 27, 2015 07:18 PM
Kamaloha
Oct 16, 2015 05:13 PM
JUICE222
Oct 13, 2015 08:50 AM
Odin
Sep 26, 2015 06:56 PM
old87yota
Sep 9, 2015 12:39 PM
