Pre 84 Trucks 1st gen pickups
front axle seals
Old Sep 14, 2008 | 07:52 AM
rottenagenda's Avatar
front axle seals
My front axle seals on both ends and needs sometype of overhual.
How hard is it to corect this problem? can i just replace seals or rebuild the axle ? Is the a kit? any info will help
its a 1979 toyota 4x4 pu
Old Sep 14, 2008 | 07:54 AM
jason191918's Avatar
Are you talking about the seals or the CV boots?
Old Sep 14, 2008 | 08:50 AM
operose's Avatar
I think you wandered into the wrong section... no CV axles on a 79 truck
Here are the scans of the factory service manual for the front axle
http://board.marlincrawler.com/index.php?topic=32014.0
Old Sep 14, 2008 | 08:54 AM
woops, never read the section. I just responded to the "new posts" section, and there was no signature. but now he added the year...
Old Sep 14, 2008 | 09:16 AM
georgiayota's Avatar
If I were you I would go ahead and rebuild the front knuckles. Marlin Crawler has a front end service kit w/ or w/o the wheel bearings
Old Sep 14, 2008 | 09:21 AM
is there any thing i need to know?
is this a straigh forword job?
and is the anyupgrade i should do at this time?
Old Sep 14, 2008 | 03:46 PM
slacker's Avatar
this might help (my best effort) .. lots of pics ..
http://toyotatrekker.proboards107.co...play&thread=63
Old Sep 14, 2008 | 03:54 PM
waskillywabbit's Avatar
If you are going to replace the axle seals, you might as well do a full knuckle service kit as you are going to tear the axle down that far anyway.
Inspect the wheel bearings while you have everything down and if need be replace them as well.
Front axle parts:
http://www.wabfab.org/products/frontaxle/frontaxle.htm
You can find an online FSM at autozone.com under "repair info"
Old Sep 15, 2008 | 06:44 AM
dropzone's Avatar
Fossilized
another rebuild thread:
http://www.4crawler.com/4x4/CheapTri...eRebuild.shtml
Old Sep 15, 2008 | 07:11 AM
BLKNBLU's Avatar
some more helpful links
http://www.birfield.com/~morgan/tech/axle/index.html
http://www.4x4wire.com/toyota/mainte...nd/solid_axle/
http://www.4x4wire.com/forums/showfl...=&fpart=1&vc=1
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jasonty
41
Dec 23, 2018 01:00 PM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
