Any interchangeable T-case gears?
Just to confirm: I don't imagine that there are any interchangeable T-case gears on the gear driven Toyota t-cases, are there? I've got the 2.28 ratio and the aftermarket ratios start at 4.0, but was hoping to get something in between. Any Landcruiser, Nissan, Lada, Suzuki gears that might fit???
Thanks
Thanks
OK thanks guys. Kinda what I thought. It's a pitty that someone doesn't make any gears that are a little more docile. 4.7 would be too low for the type of wheeling I do, and I already have 2.28 and 5.2 once I double it up. Would have been nice to have something somewhere inbetween, esp. with the weight I run on my Tacoma. I find the 2.28 just that tad too high. Personally, if I can find a guy that can make me a set of 2.57 gears, I'd take them and put a set in each case.
No need to fret.
Inchworm will custom cut gears for you. I inquired about it a while back. I was quoted 650 for the set that I wanted. I HIGHLY recommend talking to them, as they are extremely helpful, and my experience was top notch.
I ended up doing something different, but it is certainly possible.
priest16
15
Aug 6, 2015 07:43 AM
TransAmBandit
Jul 28, 2015 11:30 PM
WTB[PacNorWest]: w56 c manual trans with t-case and drivelin
89hilux1
Jul 19, 2015 01:32 AM
