Pre 84 Trucks 1st gen pickups
Checking rear diff wear?
Old Sep 29, 2012 | 08:37 PM
gbrewster's Avatar
Hi all,
I'm considering purchasing a '78 Toyota Chinook (built on a '78 2WD long bed pickup chassis). I had my mechanic look at, and he thought that the rear differential needed to be replaced -- he determined this by just turning one of the rear wheels back and forth to see how much play it had before engaging the driveshaft. So I negotiated to have the seller get the diff fixed, but his mechanic says the diff is in great shape and has no problems, so I'm trying to figure out if I should press to have the differential (8" ring gear, 4.11 ratio) replaced before completing the sale.
How can I check this myself? Is rotating the rear wheel to check for play a good method? If so, how much play is acceptable? I've been totally able to get any sort of useful answer from google, so I'm hoping you can give some guidance.
I have a similar question about one of the u-joints - seemed like it might want to be replaced. How much play do you look for there before deciding to replace one?
Thanks,
George
Old Oct 1, 2012 | 07:28 AM
gbrewster's Avatar
Thanks, 50r -- I'd post a video, but the truck is an hour away now, and I can't make the trip out there immediately, so I was hoping for some quick guidance on what you'd look for. Anybody have any rules of thumb?
Old Oct 1, 2012 | 03:16 PM
gbrewster's Avatar
I remember seeing about 1/4 rotation of a rear wheel free play before the drive shaft engaged. Does that sound excessive?
smthwsn357
May 1, 2024 07:28 AM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
icentropy
Jul 11, 2015 07:21 AM
icentropy
Jul 9, 2015 02:12 PM
