Pre 84 Trucks 1st gen pickups
Thoughts on a good exhaust setup?
Old Dec 14, 2012 | 01:45 PM
Wid's Avatar
Wid
So my 2wd '79 pickup project is in dire need of new exhaust from the headers back, and I was curious if there was any brand of headers that would be recommended by you guys here on the forums? I'm staying with stock muffler, but replacing everything at an exhaust shop. I'll do the headers myself, so I was just wondering what headers would maybe give me a little get up and go, or maybe just a cleaner look in the engine bay.
Thoughts?
Old Dec 14, 2012 | 01:52 PM
1980lwb's Avatar
Everywhere that I.have read says to keep the manifold n.just run 2.25 exhaust from it back. Now I have seen that there is gonna be a different manifold/header between 2wd n the 4wd .
Old Dec 14, 2012 | 03:25 PM
Wid's Avatar
Wid
Ok, I'll just blast and coat my stock header/down pipe black and take the truck down to the exhaust shop and have all new 2.25 pipe welded in with a new oem muffler. Thanks for your advice.
Old Dec 14, 2012 | 03:28 PM
funcrazy1's Avatar
2.25 to a flowmaster 40
Old Dec 14, 2012 | 03:30 PM
Wid's Avatar
Wid
Reasons? How does it sound?
Old Dec 15, 2012 | 07:23 AM
crazytexan's Avatar
Glad you brought this up Wid. I've been planing something myself lately, but I was just going to throw on a glass pack or some other strait through muffler but was shooting for 2". Good topic. And if someone has a video of that flow master 40 that'd be sweet too.
Old Dec 15, 2012 | 07:43 AM
Nailit69's Avatar
I Just installed a diy setup on mine, existing header 2.5" collector to a 2.5" pipe, CSI muffler, no kitty for about $130 in parts and some wire for the welder.
I bought a muffler, 4-45* angles, 1-90* and a tip and had a piece from the header to the muffler made at a shop. My bro welded it all up and it turned out sweet. I salvaged the old hangers and used all the stock locations
Sounds bad a$$ but it's loud as hell though, almost like I'm running nothing at all. If I was to do it again i'd go for 2-2.25" and a damn good muffler. My truck sounds like a V8 from the rear... don't get me wrong, i like it but i'd like it a lot more if it was quieter when accelerating.
Old Dec 15, 2012 | 08:40 AM
donomite49's Avatar
listen to mine, link in my sig..not too loud can't hear it on the hwy.
obx headers 2.5" exhaust, downey muffler similar to a flowie.
4 banger sounded good too,with a downey header, before i swapped engines.
my 20r in my 79 4x4, had a used header i picked up cheap, with the stock exhaust(no cat)it didn't pick up much, but it was hard to tell pullin 33's.
i would go with a header and 2.1/4" or 2.5" exhaust with a high performance muffler,that will give it a little more power, maybe 10-15.
Old Dec 15, 2012 | 10:30 AM
Nailit69's Avatar
..... stupid technology... ignore
Old Dec 15, 2012 | 02:47 PM
toastyjosh's Avatar
I think I am going to run stock manifold, no cat 2in piping to a thrush turbo muffler(made in usa) from autozone. I would run a header but can not find a used one.
Look for a used header in your area.
Old Dec 18, 2012 | 08:12 PM
Yopar's Avatar
Magnaflow makes a good quiet muffler.
Old Dec 19, 2012 | 07:06 AM
83pingpong's Avatar
I wonder if you can use a '94 exhaust manifold on an older 22R like mine.
That is a cast piece, but it is a tuned 4 into 2 manifold! The output is a double pipe flange, joined within a foot or two into the downpipe link down near the frame.. I always wanted to try using it-keeping the two ports separate all the way to two separate tailpipes. That would sound good, and it would be low restriction flow, definitely. I assume the bolt pattern and maybe spacing is different on the 22RE head, and it would not work.
Old Dec 19, 2012 | 07:55 AM
donomite49's Avatar
you can check exhaust manifold gaskets. if they are the same it should work.
jerusry
Oct 19, 2015 05:28 PM
crashburnoveride
Jul 10, 2015 06:39 AM
Edionne13
Jul 9, 2015 01:59 PM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
