Strange Starting Ritual
Hey guys, posting for a buddy. He's got a 1982 2wd longbed from Kalifornia and it recently has been acting a bit naughty. After sitting while he was at college, when he came home on break and tried to get it running, it wouldn't start. It would crank fine, of course, but no amount of choking, ether, or other trick would get it running.... Until we pulled the wire to check for spark and upon touching the wire to the engine while cranking it fired right up and ran fine.
Turned it off, reconnected the wire, and it started fine for the rest of the day without trouble. Next day, we go to start it and have the same routine. I've never heard of this and neither have the guys at work. I've looked online and found nothing. Please help..... it's an annoying issue.
Hmm... Try to add fuel straight to the carb slowly and see if this helps. If it seems to start better and run then you can at least say there is a fuel delivery issue. try to use a turkey baster to drip fuel in slowly while he cranks it. Just be careful of carb backfires...these can be naughty!!
Try cleaning all the ignition contact points and spark plugs; change anything that is questionable. If it sat, and you are getting positive fuel delivery, then you just need air and spark to make it run. If you have a weak spark then it may be difficult to start, or not start at all. This is definitely a weird issue. Would be much easier to diagnose in person. I will ask some friends here and see what they say. In the meantime: Good Luck! Let me know what you find out!
Poncho0206
Jul 10, 2015 06:21 PM
