Pre 84 Trucks 1st gen pickups
Weight specs of 81 JT4
Old Oct 16, 2012 | 07:00 AM
timbo1011's Avatar
Does anyone know where I can find the gross weight, gross vehicle weight rating, gross bombination weight rating, and empty weight of a 1981 JT4 truck??? ----other than on the truck------I'm looking for specs I guess.
Old Oct 16, 2012 | 07:22 AM
Bingle's Avatar
2wd or 4wd? Should be on the drivers door jam either way, if I remember correctly. What's the reason for wanting to know this? More info helps us give you better answers. I have a 81 4x4 and can look tonight if that's the truck in question.
Old Oct 16, 2012 | 08:58 AM
timbo1011's Avatar
The truck is a 2wd..
I am buying this truck and the sticker is gone from the door jam. The title is in another state that mine and that info is not on the title...............but in my state the application for title asks for these weight ratings..............thanks
Old Oct 16, 2012 | 12:00 PM
trekkerpaul's Avatar
If there is no door jamb tag you should not buy the truck for starters. It is likely to be stolen. Check the frame VIN on the passenger side wheel well to see if it matches the other 3 tags.
Is this truck a long bed or short bed?
Old Oct 17, 2012 | 04:47 AM
timbo1011's Avatar
Yep.......all the numbers match up and the title is good. This truck is a short bed.
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
Obmi
Oct 4, 2015 11:30 AM
dbollier123
Sep 29, 2015 05:23 PM
