Pre 84 Trucks 1st gen pickups
A swap question
Old Nov 27, 2012 | 06:40 AM
jastamjas's Avatar
A swap question
I have been looking on here for a long time and I can't find the answer I am looking for. I am getting ready to swap out a 20r out of my 1980 and put in a 22r from a 1983 and I can't find if I need the PCM out of the 83 or what other wiring stuff I need.
Old Nov 27, 2012 | 11:18 AM
Bingle's Avatar
I'm not sure what a PCM is, but should be pretty much a drop in situation, other than the emissions crap. Best bet would be to strip all that off if you can get away with it (I don't know where you are located). Stripped down 22R with a Weber is one of the most easy to work on/reliable setups out there. Bonus if it's the doubble row timing chain.
Old Nov 27, 2012 | 01:01 PM
jastamjas's Avatar
Thanks for the info i did know if i had to use the 22r eng. Computer i am going to rebuild the eng. Before i put it in whats the best rebuild kit to use
Old Nov 27, 2012 | 01:58 PM
Bingle's Avatar
"Best" is really a matter of opinion. To an extent it depends on what you're going to do. Are you doing a full rebuild? adding performance parts? or just a "freshen up" kind of rebuild? I personally like LC Engineering, their quality is top notch, but they aren't the cheapest. Quite a few people on here like engnbldr.com.
The more info on what you have and what your plans are, the better advice we can give you!
Old Nov 27, 2012 | 02:24 PM
95yoter8's Avatar
I use Top Line bearings, rings, timing chain set, and timing gaskets. Great company they come out of Chicago and can be at a local dealer in a day. I usually use Toyota Head gasket too.
Old Nov 27, 2012 | 05:37 PM
jastamjas's Avatar
I am just going to do a regular rebuild its going to be my daily driver I don't plan on putting any performance upgrades I already have a webber carb
coleypull15
Nov 3, 2015 07:41 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
KBar
Jul 13, 2015 06:01 PM
Coreyr384
Jul 10, 2015 11:13 AM
