Pre 84 Trucks 1st gen pickups
Noob transmission ID
Old Dec 4, 2012 | 06:23 PM
LA80sr5's Avatar
Hey there,
Been lurking here and and over on pirate for a while now, and I finally have a question. I've been searching for a 5 speed to replace the l43 I believe to be in my 80. I found what I believe to be a w56 with top shift transfer case on Craigslist today...post said it came out of a 89 with a 4cyl...from research I was under the impression that they went to forward shift in 89.Im just wanting to double check,here's the pic. Thanks
Old Dec 4, 2012 | 06:40 PM
dropzone's Avatar
Fossilized
Looks top shift to me.
So you know a W series trans is 4" longer than the L series your truck came stock with and will require that you move the cross member back, lengthen your front drive shaft and shorten the rear?
Old Dec 4, 2012 | 06:46 PM
LA80sr5's Avatar
Yep that will be the plan for the future. While I'm at it I will probably go ahead and double the tcase...just want to jump on this now bc it's a good deal.
RobotMoose
Feb 22, 2020 07:44 AM
pickle6415
Oct 19, 2015 08:08 AM
irv
Oct 1, 2015 09:49 PM
briholt
Sep 20, 2015 10:26 PM
kelly1450
Sep 2, 2015 12:29 PM
