Pre 84 Trucks 1st gen pickups
83 fan/vent problem
Old Dec 10, 2012 | 10:47 PM
83Longbed's Avatar
83 fan/vent problem
I had a deck installed a few months ago and immediately i noticed something was wrong. My heater and defrost work in my truck, but after the deck install whenever i turn the heater/defrost on, the vent/fan turns on as well and i am no longer able to switch the bottom switch from defrost/heat over to the vent. This defeats the purpose of my heater and im tired of wearing a jacket while i drive. Any ideas? Thanks
Old Dec 11, 2012 | 01:07 AM
dropzone's Avatar
Fossilized
The 'installer' screwed up and fubarred something while under the dash.
you can download the manual here
https://www.yotatech.com/forums/f114...wnload-261385/
Old Dec 11, 2012 | 03:30 AM
suncomb1's Avatar
I have a 1983 truck and I only have one switch that operates my electric fan. The heat, temperature, defrost, etc are operated by lever / cables (color coded). Is that what you have? If during the deck install they did not put the cables back on the proper device that they are to be mounted on or did not lock the cables into their retainer tabs, that would cause problems. As far as the electric fan switch goes, there is only one plug at the switch, so during the removal for the deck install you just unplug it for removal and then reconnect it during reinstallation.
Old Dec 11, 2012 | 04:37 PM
slacker's Avatar
good info. right there ...
Old Dec 21, 2012 | 08:38 AM
83Longbed's Avatar
sorry it has taken me days to respond. I have been in couch surfing and all that jazz but i tore into my deck and i think its the actual heater/ ac core thats in the dash. The levers aren't working properly so i cant switch over to vent which makes me think that the installer broke the lever in the on position. Thanks for the diagrams tho dropzone, i dig your trekker
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
