Pre 84 Trucks 1st gen pickups
weber 32-34 dft? will it work?
Old Nov 8, 2012 | 08:57 PM
406yota's Avatar
hey everyone ive tried searching a few times about this but cant find anything even on google. ive been on here for awhile looking around but this is my first post. well story is guy on craiglist has a weber 32-34 dft for cheap and new so i was wanting to buy it and cant find anything about it ive looked at pictures and it looks like they both have a square bolt pattern but idk. im pretty new to toyota's actually this is my first one. so back to my question will it work?
Thanks
Old Nov 10, 2012 | 06:44 PM
d-wood's Avatar
Whats your year and engine? Not that it matters but is it tow wheel drive or four wheel drive? Also do you mean a 32/36 weber?
Old Nov 10, 2012 | 09:48 PM
406yota's Avatar
oh sorry its an 80 4x4 with a 20r and the carb says its a 32-34 its a little different form a 32-36 from looking at them
Old Nov 10, 2012 | 10:18 PM
d-wood's Avatar
I'd say. I looked on weber and didn't see one. I'd call weber and ask about it. Maybe that guy typed wrong. You said you could see the writing on the carb?
Old Nov 11, 2012 | 05:24 PM
406yota's Avatar
yea it says it right on the baseplate i also looked on the weber site and couldnt find it but heres some picture
Old Nov 11, 2012 | 05:35 PM
d-wood's Avatar
I hope somebody with more exerience chims in for you. Im gonna do some searching and see what I come up with. Did you call Weber and ask them? Its definetly a Weber. How much they asking?
Old Nov 11, 2012 | 05:45 PM
d-wood's Avatar
im gonna go out on a limb and say it wont work for yours. Its probally for a different vehicle and modifies for that purpose. Just my thoughts............. I looked all possible carbs for your vehicle and that didnt pull up. Ask the guy what it went on. Im curious to know.
Old Nov 11, 2012 | 05:48 PM
KryptoRoxx's Avatar
Same here on that. If it works well it would work....but I have never heard of that specific carb. Looks like it's in decent shape though. I think your biggest problem if you were able to make it work would be the throttle linkage. You'd have to come up with that yourself. It's not impossible and I would say from the sizes of the barrels that it "could" work as far as volume goes.....but finding parts would probably be difficult....and getting help would be as well.
If you could take a picture with the linkage in it from the side. That will speak volumes for if it would fit or not. The height would also be handy since the throttle linkage can only sink so far with the weber spacer.
Old Nov 11, 2012 | 06:54 PM
406yota's Avatar
hope these can help. i actually bought it thinking it was going to fit and once i saw it knew it wasnt a 32-36 but it was so cheap and in good shape i had to buy it and hope it would work.
Old Nov 11, 2012 | 09:16 PM
KryptoRoxx's Avatar
It could fit....you're right about the holes. What worries me is that hole off to the side. Also it will definitely be custom linkage. I think it sits lower on the Carb than the 32/36.
If you are going to attempt it I would get the repair manual for it. There are some vacuum line connections on there. I know the 32/36 doesn't have those. Was that circular piece in the box the air filter adapter?
The Carb is short enough to fit. Whatever air filter housing you get to go along with it make sure it has clearence with the hood.
All in all its a cool Carb and I hope it works for you. Make sure you do your research on how everything will be run, connected, and there's a chance you will run a very unique looking Carb.
Good luck to you man.
Old Nov 12, 2012 | 04:33 PM
406yota's Avatar
thanks for the help krypto im glad to know i didnt waste the money on it. yea all the stuff in the box came with it and yes thats the air cleaner adapter. i wasnt to put an air cleaner like the 32-36 hopefully it will fit i like the way they clean up the engine bay.
Thanks
Old Nov 12, 2012 | 04:50 PM
KryptoRoxx's Avatar
Keep us posted on how it works out or if it doesn't....oh and PICS lol
Old Nov 12, 2012 | 05:47 PM
406yota's Avatar
will do man
Old Jun 20, 2024 | 09:49 AM
pishta's Avatar
did you ever get this to run? I bought one as its actually an OE (C.A.R.B california exempt) smog capable carb for a 1.6-2.0 motor, '82 ish Ford Escort/Lynx 1.6 OEM carb) , usually Datsun but in case a Mazda 2.0 in a 82 B2000. These are veryt expensive new for some reason and there are no direct Chinese knockoffs yet. The OE D-133 has all the jets and corrector listed so it will pass smog. Mine looks complete, is that a fuel cutoff servo out the side? Where is the idle mixture screw? I had a Holley 5200 (mini weber 32/36 DFAV, smaller fuel bowl only) and a genuine weber DGEV and both seemed to work but without an exhaust gas analyzer and a pocket full of jets and air correctors, I wont be able to get these to pass smog let alone the physical inspection with the wrong non OE listed carb. Webers are nice if you got the jets to tune otherwise there is only 1 screw to turn to adjust AF and you can only turn that .75 turns before your 'out' of the supplied idle jet.
kazuya2416
Apr 5, 2024 02:17 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Yota.Jay
Jul 23, 2015 08:08 PM
Johntom240
7
Jul 13, 2015 12:18 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
