Pre 84 Trucks 1st gen pickups
1982 4x4 p/u wheel availability ??
Old Dec 4, 2012 | 03:55 PM
SVOman8284's Avatar
Hey guys does anyone know of any white wagon style wheels that will fit a 1982 4x4 ?? i called pro comp and they said their wheels wont fit ?? i was like wtf ?? I am searching for white 15x8 6-5.5 wheels wagon style.. Any input guys on what brands/style to look for ? Thanks again -J
Old Dec 4, 2012 | 04:53 PM
83pingpong's Avatar
I bought a set of American Racing steel wheels a few years ago. Don't know if they can still be had. I found this:
American Racing white wagon wheel
4WD wheel for 1st gen are 6 x 5.5" bolt pattern. If you want stock- 15"
There are 16" alternatives.
Width for 30-33" tires should be 8to10 inches. Check tires you want for rim compatibility.
Want stock tires, you'll be lucky if you can find 7", and possibly won't find a 6.5" or less width.
If you want black, possibilities open up... more styles, more sizes.
Old Dec 4, 2012 | 04:59 PM
83pingpong's Avatar
Wagon Wheel steel wheels
Here's another supplier that looks live:
Wheel and tire combos dot com
By the way... I ended up buying the black version of that wagon wheel pattern, but the white was available (it was 2WD-5 bolt 4.5 pattern). Looks like you CAN get the 6-5.5" white version, AND for less than I paid (under 50$ each-cool). You're in luck!
Here's more models in black steel wheels:
4x4groupbuy.com-black rock wheels
They have "blade", "dune", "lobo", and "series 997" styles, with one that fits in each pattern (6-5.5" bolt pattern). If you just click on one of those wheels, and then wait for page to load, there will be sizes listed on the left-easier to find the style/size. I see "made in USA" on the Lobo wheel pages. Cool.
Old Dec 9, 2012 | 05:42 AM
83pingpong's Avatar
I've been looking into new wheels and tires. The 31 x 10.5 tires on the truck are fine for deep mud, and the wheels look good, but I want a narrower, tall tire with load range D or E. It won't be quite as good for deep mud, but it will cut through snow better, won't hydroplane so easily, and provide better treadlife if I choose right. Yokohama Geolander has a good reputation for treadlife and grip, and there are 16" options with load range D. BF Goodrich also has the All-terrain radial A/T in some similar sizes, and they go up to load range E! That would be a tough tire.
The Black Rock wheels can be had for less than $80 in 16" sizes. Maybe after Christmas I can do this. The problem is that I found a couple of 22R engine blocks (one very good), and I want to start a complete rebuild. I need more money already! I should probably get started on the engine first. That won't cost as much, at least at at first
Colington
Mar 8, 2020 09:51 AM
jasonty
41
Dec 23, 2018 01:00 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
