Pre 84 Trucks 1st gen pickups
L50 trans
Old Feb 14, 2013 | 10:37 AM
Vio Lence's Avatar
L50 trans
Does anybody have an L50 for sale or will the L52 fit in my 81 without any modifying?i have searched and searched but can't find one
Old Feb 14, 2013 | 11:13 AM
Bingle's Avatar
L50 and L52 are interchangable/no mods to swap. The L52 is supposed to be the stronger of the two.
Marlin Crawler sells em.
Old Feb 14, 2013 | 12:21 PM
83's Avatar
83
For the price of your first-born
Depending on what you're going for, you could just try to find a used one. Marlin is the leader, probably, in rebuilt Toyota transmissions, but you pay the price for them!
Old Feb 14, 2013 | 02:21 PM
TheChewMaster's Avatar
I would get a used one
Rebuilding them is very doable, but still quite tedious. I decided to just search and search for an L52 instead of working on one.
If I was to buy a new/rebuilt one it would only come from marlin crawler, because trannies/cases is what they specialize in, and they go over everything. But 83 is right they are expensive like at least a grand
Old Feb 14, 2013 | 03:03 PM
Vio Lence's Avatar
I would love to have one from marlin but yeah it's not cheap and I am cheap so that's not gonna happen for a while.i would like to find a used 52.5th gear in mine took a dump so technically it's a 4spd lol.
Old Feb 14, 2013 | 04:24 PM
cman1's Avatar
have it re-built!
Old Feb 23, 2013 | 04:42 PM
FIRTH4X4's Avatar
Marlin sells them, but they charge out the ass for shipping, and they are REAL picky with cores. Its a gamble wether or not you will get your core refund back. Find one on craigslist or junk yard, buy kit on ebay, overhaul yourself. You can find them all day long for $300 or so. Kit is around $150. Here is a link bro.
L52 kit for 80mm input bearing:
http://www.ebay.com/itm/Toyota-L52-L...1c9c9c&vxp=mtr
Old Feb 23, 2013 | 06:27 PM
Killgore Trout's Avatar
I have a good L50, I'll trade you striaght across for a good L52 :wink wink:
Are you replacing a busted 5 speed, or are you evicting an old 4 speed?
Old Mar 5, 2013 | 11:49 AM
yota81's Avatar
I'm not sure if I have the L50 or L52, and mine needs a rebuild. Is there a way to tell which one I have externally? I swapped a 5 speed into my truck, but was not told which model it was.
Old Mar 5, 2013 | 12:12 PM
I read that on the nosecone of an L52 you can find a small oil weep hole, the L50 has none, do a search on the marlin crawler forums. Lots of info to be found there.
Old Mar 5, 2013 | 12:20 PM
yota81's Avatar
thanks...i'll look around
Old Mar 5, 2013 | 01:48 PM
andy4x4's Avatar
good luck finding one lol
Old Mar 6, 2013 | 04:31 AM
FIRTH4X4's Avatar
The only way to ID an L50 vs L52 is the input bearing. Take off the 6 12mm head bolts that hold the bearing cover on and read what the bearing has on it. L50 has a ball bearing or roller bearing option, L52 uses 80mm ball bearing.
Old Mar 6, 2013 | 06:16 AM
83's Avatar
83
I think that you're right. At one point there was a tranny discussion that Big Mike from Marlin posted in, and he mentioned something about a weep hole being the only way, without tearing it apart, to ID an L50/L52.
I don't feel like searching for that thread, though...you could try searching his profile for his posts, though.
Old Mar 6, 2013 | 07:05 AM
yota81's Avatar
thanks again...
Old Mar 9, 2013 | 02:44 AM
dropzone's Avatar
Fossilized
I read that on the nosecone of an L52 you can find a small oil weep hole, the L50 has none...
See Quote Below
from a couple of years ago:
Originally Posted by BigMike
Since I am at work right now, I asked Marlin if there are any other ways than what I mentioned, and he said to check if the nose cone has an oil seep hole right on the release bearing section of the nose cone. If so then it's a L52. It is a small 1/8" or 1/4" hole (I don't know the actual size) and it's positioned on the machined release bearing section of the nose cone straight down at 6 o'clock. Marlin said he'll simply reach into the bellhousing and grab the nose cone, and immediately he'll know if it's a L50 or L52 if he feels that hole or not.
That is much better than removing the nose cone, so definitely cool, thanks Marlin!
BigMike
tyzsdaddy
Jan 16, 2016 09:19 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
beebeeri000
Oct 2, 2015 10:42 PM
tshort48
Sep 27, 2015 01:04 PM
Odin
Sep 26, 2015 06:56 PM
