Pre 84 Trucks 1st gen pickups
v6 3rd Front Solid Axle
Old Jan 4, 2013 | 07:44 PM
Brando338's Avatar
Does anyone know if the 4 Pinion v6 rear end diff will work in a toyota solid front axle? My concern would be the splines not lining up. I am looking to SAS my 90 and would like to retain stock gearing if possible for the time being.
Old Jan 4, 2013 | 09:53 PM
JonnyBoy's Avatar
It'll work, and the splines will match. Not a different number or alignment, it'll actually be slightly stronger cause the third housing has some more reinforcement to the casting.
Old Jan 4, 2013 | 10:03 PM
Brando338's Avatar
Thanks Jonny! someone had to know.
Old Jan 5, 2013 | 04:47 AM
rattlewagon's Avatar
Read this:
http://home.4x4wire.com/erik/diffs/
Yes it will fit.
The extra fins are for cooling, its stronger because of the 4 pinion carrier that also has larger bearings . All 8" toyota 3rds are 30 spline.
since were talking about a 90, this should probably be in the 86-95 section..
Old Jan 5, 2013 | 07:57 AM
Brando338's Avatar
yeah i just figured I would put it in the first gen section because I figured a first gen owner would have more solid axle knowledge. Moderators feel free to delete this thread.
Flying91
45
Apr 11, 2024 04:39 PM
gieselman
Oct 12, 2015 01:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
scottyg486
Jul 19, 2015 05:34 PM
ItsJustD
Jul 7, 2015 07:49 AM
