v6 3rd Front Solid Axle
Does anyone know if the 4 Pinion v6 rear end diff will work in a toyota solid front axle? My concern would be the splines not lining up. I am looking to SAS my 90 and would like to retain stock gearing if possible for the time being.
Read this:
http://home.4x4wire.com/erik/diffs/
Yes it will fit.
The extra fins are for cooling, its stronger because of the 4 pinion carrier that also has larger bearings . All 8" toyota 3rds are 30 spline.
since were talking about a 90, this should probably be in the 86-95 section..
Yes it will fit.
Flying91
45
Apr 11, 2024 04:39 PM
scottyg486
Jul 19, 2015 05:34 PM
