Pre 84 Trucks 1st gen pickups
81 Leaf Spring Problem
Old Jan 18, 2010 | 09:27 AM
bajabloke's Avatar
My Baja rig is an 81 long bed 4x4 complete with CanBak shell, RTT, solar panel, Engel fridge, deep cell battery and a 20 gal water tank. My point is I carry a lot of weight which my truck handles well. However my leaf springs are now going in the wrong direction. How do I calculate what to replace them with and welcome any suggestions
Old Jan 18, 2010 | 07:27 PM
yota81's Avatar
being that you carry alot of weight on a regular basis with a fairly light truck, you want a leaf spring with many leaves but not much arch...the leaves will still move and flex with the terrain but will help with the load. Maybe a custom job, and there are companies, such as Deaver, that can help with that.
Old Jan 19, 2010 | 12:54 PM
Jeff D's Avatar
You are in southern California, give the guys at Camburg Engineering a call. They're up in Huntington Beach and build Baja 1000 race trucks. They do lots of custom suspension work and I'm sure they could give you some advice or set you up.
http://www.camburg.com/
Old Jan 19, 2010 | 02:57 PM
peow130's Avatar
Chevy 63" springs will work..
They're for a half ton pickup.
The truck will ride better, and you can carry a bigger load..
You could also take some old rear springs and put them up front for added lift.
Old Jan 19, 2010 | 03:36 PM
desertcamper67's Avatar
And don't forget National Spring down in Santee. Are your rears going negative or just the fronts?
Old Jan 23, 2010 | 07:06 AM
bajabloke's Avatar
Thanks for the input.
Just found out I work with a colleauge who has access to a set of scales, so when I'm fully loaded will weigh the truck and then start talking to the suppliers you guys recommended. Thanks again for everyone's input. b/b.
Old Jan 23, 2010 | 07:16 AM
4Crawler's Avatar
Another custom spring place is Alcan Spring, I run those on the rear of my '85.
- http://www.4crawler.com/4x4/4R_suspe...gerRearSprings
Or try OME, they have a 2" lift spring in a medium and heavy duty spring rate:
- http://www.arbusa.com/
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
kyletbert
Jul 17, 2015 11:39 AM
cars-guy
Jul 11, 2015 07:51 PM
Nickdigg
Jul 7, 2015 06:04 AM
