Pre 84 Trucks 1st gen pickups
Used engine questions
Old Mar 1, 2010 | 05:56 PM
georgiayota's Avatar
I just bought a running engine out of a 83 celica with 170,000 miles. What all should I do before droping it in my pickup? I am going to put new main bearing, rod bearings, thrust washers, timing chain, gaskets. The main thing I want to ask is about honing the cylinders, I never have honed any thing before. Should I be good or go ahead and hone it also? Thanks in advance.
Old Mar 2, 2010 | 03:46 PM
aadown1214's Avatar
Have you by chance pulled the head to see what the cylinders actually look like visually? If the engine is or was running when you got it, and doesn't knock,seem tired or smoke, id swap some seals and see what it'd do. I'm guessing you want to avoid rebuilding?
Old Mar 2, 2010 | 03:56 PM
The walls are shiney and I'm looking to avoid rebuilding it. I just want to freshen it up where I can drive my truck again. I just lost my job so I don't have deep pockets any more. I think I'm just gonna get new seals, bearings, and rings. I want to hone the cylinders but thats something I've never done. Any advice? I can post pics if you want to look at what I got...
Old Mar 2, 2010 | 04:02 PM
aadown1214's Avatar
I'll do almost anything to an old engine, but I walk the fine line between what I know I can do right, and what I'll sling $ to a machine shop for. Personally, I'd probably look into the head more than the cylinders if they're not scarred up. Throw in some pics, lets see what you got ahold of. How far out of Statesboro, if you need some spare parts I can see what I can dig up next time I'm down in Warner Robins with the family.
Old Mar 2, 2010 | 04:10 PM
I got a brand new head and I bought the engine because I needed a good block because mine got ate up by the crankshaft when the thrust washers were lost. I bought the engine and it came with the block with rods and pistons, crank, head, a new timing cover, valve cover, intake and maybe some other stuff. Give me a few minutes and I can get pics up.
Old Mar 2, 2010 | 04:15 PM
woody87's Avatar
i honed mine, if ur gonna put the new rings in it doesnt hurt, just make sure u have no play in the pistons
Old Mar 2, 2010 | 04:29 PM
cylinder one and two
the crank
the head
cylinder three and four
Old Mar 3, 2010 | 03:12 PM
woody87's Avatar
wow! ya i would hone it
Old Mar 3, 2010 | 03:30 PM
iselloil's Avatar
I would have bought a short block from sunwest in medical lake wash. Or elsewhere
Old Mar 3, 2010 | 03:34 PM
woody87's Avatar
well i got a 22re for sale just rebuilt it 2yrs ago, i rebuilt it when the truck had 142k on it, it runs strong! 500 bucks u want it??
Old Mar 3, 2010 | 05:07 PM
83YotaNator's Avatar
fell the cyl walls and see if you can feel groving or scratches. Just run a quick hone up and down same speed and pattern for all cyl
bigjstang
Jun 2, 2025 03:56 PM
kazuya2416
Apr 5, 2024 02:17 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
