Pre 84 Trucks 1st gen pickups
Lesson learned about cooling systems!!
Old Jan 20, 2010 | 05:56 PM
Ilovemountains's Avatar
Cool Lesson learned about cooling systems!!
Monday I flushed the cooling system in the 82 Trekker, put new upper and lower radiator hoses on it, a new thermostat / gasket and a full system flush. Well, this evening I took it out, drove about 8 miles to a local gas station and filled it up... When I stopped at a highway crossing I smelled coolant and thought, oh ........The temp guage was good, slightly left of the middle so I drove it home...I pulled it in the garage this evening and sure enough, shes leakin!!!!!! The old radiator cap, leaking... the old heater hoses, leaking!! I guess with the new 180d thermostat its running at proper temp and the old heater hoses dont like it! I really wish the radiator had a drain valve on it...Im going to drain it again and replace ALL of the cooling system hoses after tonight... I think I need the " pipe to engine " large hose and the rest are just "heater" hoses, along with a set of all new clamps. In the back of my mind I knew I should have just torn it down and replaced all of the hoses but looking at them and feeling them they were pliable.. Lesson learned, a 28 year old truck thats not really been ran in a few years probably needs all new hoses... At least I made it home and dindt need to get it towed!
Old Jan 20, 2010 | 09:10 PM
benmmc's Avatar
Yep, I blew a heater hose on a road trip a couple weeks back. That led to many other problems as well. By the time I got back, my radiator was leaking like nuts. I replaced it (mine does have a drain valve).
Now it's heating up slightly, but only on the interstate. Not sure what it is, but I hate cooling systems. Once one thing goes, it's like you gotta replace it all.
Old Jan 21, 2010 | 01:10 PM
Al's Chop Shop's Avatar
been there, done that!
Al
Old Jan 21, 2010 | 02:31 PM
Gov't Mule's Avatar
My father was a mechanic for almost 40 years and that's one of the first things he taught me. He always said if you have an older vehicle and you don't want to or aren't ready to replace every hose in the cooling system and possibly even the radiator, heater core, water pump, etc. then DO NOT "flush" the system, just drain it and refill it with new AF and clean water.
Old Jan 21, 2010 | 05:16 PM
Good call, I ran a bottle of cooling system cleaner through it with strait water for about an hour then let it sit over night. I flushed it with the hose until it ran clear and put it all back together with fresh 50/50 antifreeze... Im going to drain it this weekend and start swapping the heater hoses, I really really hope the heater core and rad are OK, the thought of swapping the core erks the crap out of me!
Old Jan 25, 2010 | 05:25 PM
red1983's Avatar
Yep! Happened to me too. Replaced a leaking RADIATOR CAP and ended up with all new hoses.
Old Jan 26, 2010 | 01:22 AM
i disagree. i didn't flush the system, simply drained and refilled with new hoses and then the crud finally kicked up on a road trip. killed my radiator and almost took the head gasket with it.
FLUSH.
Al
Old Jan 26, 2010 | 08:15 AM
Gov't Mule's Avatar
The whole idea is to maintain it properly with regular coolant changes and prevent the crud from building up in the first place. And I didn't say "don't flush"...I said "don't flush unless/until your are prepared to replace everything".
Old Jan 28, 2010 | 05:33 PM
sure, until you pick up a rig that's been sitting a while. not much you can do to prevent that!
Al
Marsheen
Feb 17, 2016 12:29 PM
Ohio4Runner
Aug 31, 2015 05:45 AM
mbomberz1
Aug 8, 2015 06:57 AM
TJWilly
Jul 31, 2015 02:05 PM
kyletbert
Jul 17, 2015 11:39 AM
